Hi guys,
Have always worked on laptops for my need all this while..I am into cell phone repairs and my work takes up a lot of Usb ports, as i have to plug in dongles for various cell phone types....recently i laptop i was working is not sufficient for my day to day work...now there is a need of a computer as these dongles tend to consume a lot of power to flash or unlock a phone.....which a laptop does not provide......
Now the thing is i am gonna use this desktop computer for at least 2 years with out upgrade so..also i am like a bit of gaming so in a couple of days or so i wud like to add a graphic card if the finance permits(including time..which is less for me).
My budget is abt 20k(20,000) (by da way i am from goa and will purchase the computer form laminton road...plz suggest where can i get the best prices)
1. What is your MAX budget?
--20,000..may exceed 5k extra
2. What is the purpose of the computer?
cell phone flashing and partly gaming
3. Which OS are you planning to use?
mostly XP SP3 however if our software works on windows 7 will might work on that..in the near future
4. How much hard drive space is needed?
500 GB
5. Are you one of the types looking out for "future proof" configurations?
yes...especially the usb 3.0 has atleast 8 usb ports or so..(lol I know i am demanding)
6. Which city do you live in and are you open to buying from online shops?
I am from Goa and will be buying the components from mumbai at Laminton road
Plz suggest me the best rig which gives me 3.o Gh minimum....and wats the best motherboard to have as many usb ports as possible
Br
Clifford (goa..the golden sunset state india)
