Re: Monitor
Did I mention the "apples to apples" bit or are you adding that?
It's very hard to rate two monitors subjectively when you are not testing them together, because half of the testing is relative and subject to the differences your eyes see. The Spyder3Elite tests apart, everything is subjective.
I'd say the BenQ was better priced and offered more value. Not everyone wants a memory card reader on their monitor, which I believe the 2230FM had. It's also a 22" VS a 24" - same price - similar performance - no brainer - go with the larger screen.
CPU: Intel Core 2 Quad Q9650 (Ultima 90i cooled)
Mobo: ASUS P5K Deluxe
RAM: OCZ XTC PC8500 4x1 GB - 1066 MHz @ 5-5-5-15
Graphics: ZOTAC GeForce GTX 285 AMP! @ 700/2600 MHz
Storage: 1 TB WD Black + 500 GB WD 5000AAKS
OS: Windows Vista Ultimate x64 (genuine)
SMPS: Corsair HX 850W
Speakers: 'Sangram' modded Altec MX 5021
Cabinet: Lian Li A71F
Display: ViewSonic VX 2025 WM
