Old 07-03-2010, 07:13 PM   #1 (permalink)
Default Need to build cpu only, for 45k +- 10K
I need to build cpu my budget is 45k +- 10k, (monitor not required as i am using my 32" lcd tv) please suggest me with good configuration pointed at performance (gaming, video processing) and cpu that could make worth for more time, i live in haridwar so if anybody belongs to here please suggest me where to buy the right hardware in haridwar.
Last edited by fireball424; 08-03-2010 at 05:13 PM. Reason: some sudden change in budget and for more clearification.
fireball424 is offline
Old 07-03-2010, 07:43 PM   #2 (permalink)
Default Re: Need to build cpu only, for 45k
can u give the usage of the pc? if gaming than the monitor screen size wil help provide a good config.
Sam is online now
Old 07-03-2010, 10:57 PM   #3 (permalink)
Cool Re: Need to build cpu only, for 45k
firstly, i are going to get a new monitor, please get a 24".. trust me i made that mistake and i regretted it everyday of my life.
secondly, if you plan to maintain your card for more than 2-3 years, then get a 5770 or a 5850.
thirdly, get the i5 series quad core or a phenom 2 series cpu.
fourthly, 3-4 gd ddr3 will suffice, but would suggest 2gb for now as ddr3 is still costly.
lastly, go for the cm690 case as its got a lot of room and cable management features.
so this is the price list:
intel core i5 750 lynnfield 2.66ghz ---- 9840
gskill 2x2gb ddr3-1600-9-9-9-24---- 6747
Gigabyte GA-P55M-UD2 / MSI P55M-GD45 (crossfire/sli, 2x pcie x16) /MSI P55-CD53 (ATX, 1x pcie x16)---- 7350/6720/7245
wdc 1tb black/green------ 5618/4440
acer 23" hd/Asus MS236H 23" LCD/Benq 24" G2420HD LCD -----8969/15775/11039
POV - Black Diamond 400 Watts /Coolermaster Real Power Pro 460W/corsair vx450 -----2258/3535/4130
cooler master cm690--- 4210
xfx 5770/ any 5850 ------ 9993/15000
on an average you'll end up spending 45k excluding the monitor (bargaining skills etc)
the other factors such as optical drive, cpu cooler, case fans, keyborad etc are all up to you...
note: buy a decent cpu cooler (cooler master ---- prefer) and assemble it yourself..
best of luck
warlord1609 is offline
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
Please List Basic C2D / Dual Core Overclocking Tips Choto Cheeta Overclocking 101 18-12-2007 09:31 PM
Nokia Processors - Hope its useful! solomon_paulraj Mobiles and Tablets 4 31-10-2007 02:57 PM
- by c4u
