1. Whether I should buy assembled PC or branded PC?
If you are a techie yourself and don't mind getting your hands dirty from time to time then I would definitely go assembled. However note that it really isn't the cost or the hardware thats going to be a deciding factor when you commit to a business plan but rather to the legalities of your firm. Getting licensed software on 30 PC's itself could b a big pain unless you plan on going Open Source which wouldn't exactly be a wise decision if you don't know what you are doing. Although you might get away for some time without any checking I can guarantee that sometime someone is going to come by for inspection of licenses.
2. Which printer shall I buy that takes the printing load of all the 30 systems, it should be a black ink laser printer?
There are tons of printers you can choose from ideally you want a network printer which connects directly to your network. And do remember you might have 30 systems but the chances of all 30 printing at once is kind of astronomical so don;t go all overboard its a waste of investment funds if you ask me . But then again the final decision is your of course.
3. Is there any way to connect all the systems to a single CPU, rather than buying 30 CPUs?
Yes there is . Refer thin client usage and again there again you might be looking at licensing issues I'm not sure how licensing works on dumb nodes but I'm sure M-Soft has some kind of plans for those as well. Whether it would be cost effective for a cybercafe environment is a question which will require someone to do a cost analysis which I haven't done so can't help you there.
4. What are the other things that I may require?
Well you only have mentioned that you need PC's so basically you need whatever you want your cybercafe to cater too. Example what kind of customers do you expects.
Gamers -> Get some good stuff in there licensed games etc.
Executives -> Then make sure you have some Wireless Access Points for them and the required space
Education -> Adequate materials
If you want to exploit the opportunity Id plan for adding something like small snacks and drinks for your customers but Id only go that far once you open and make sure you receive a good number of customers.
Well ventilated space . I can't emphasize on this . No one wants to be all sweaty doing whatever they do. Theres tons of stuff you could think up , it just requires a bit of planning so hop by your competition and see if it arouses your creativity.
5. Any precaution, do I need to take?
Alot, bandwidth usage, maintenance, theft, licensing issues etc. Maintenance is going to be a pita if your supplier is a slacker. However as said before unless you are going to be running at 100% capacity always it shouldn't be much of a problem. However if you go for a thin client solution God save you if your server for some reason botches up.
Once you get connected to the Internet you get assigned a certain IP address which all the traffic comes to . This can be dynamically assigned or statically assigned. Dynamic means that it may vary each time. Static basically means you will have the same IP each time .
7. Which Internet Connection shall I install?
Well 30 systems is going to be alot of traffic so plan with a bit of future proofing the last thing you need is to be ending up paying for MB. Ideally you would want an unlimited plan but this would depend on the cost and the area you are located in I guess.
8. Is it allowed to use the domestic Internet connection commercially?
Nope, if you manage to get one installed I bet you get fined within the first two months.
Further I would refer to some folks like ChotoCheetah on this forum or get his email from his blog and contact him he should be well versed in this stuff. For further help on Windows networking you could check with some of the MVP's on this forum assuming they do come here or just get their email and message them. Id check with folks like iMav, Gx, Vishal Gupta etc .
As far as the above info goes I think everything should be approximately correct but make sure you do further research into it before making any purchases. Maybe you could mail in your query to Digit and might get help too
Cheers
PS: The backup power solution for 30 PCs is going to be a nightmare to be decided on. Personally Id go straight to the company for details like that. I was placed with the task with purchasing a power solution for 15 computers and trust me when I say this is one nasty task to deal with.
