Old 04-03-2010, 09:36 PM   #1 (permalink)
Default 24" LCD Monitor
I was looking for a 24" Lcd monitor.Only thing which easily available in Bangalore in Benq G2420 which is 10.7k. and my budget is around 11-13k.
Please suggest me a gud 24" monitor from your experience.I was not too sure about it as there is not much reviews about it Benq G2420.
I cant see much 24" option in various brands..Hows the comparison of clarity for 24" in this range as compared to 8-9k 22" ones? Is it the same? Please let me know your experience.
Thanks in advance
maximus is offline
Old 04-03-2010, 10:20 PM   #2 (permalink)
Reviewerus Prolificus
Default Re: 24" LCD Monitor
That monitor is pretty decent. I tested it, and found it to be excellent bang for buck. Sure, it's not the best around, for that budget, it's about your best choice. Go with it, you won't be disappointed...
CPU: Intel Core 2 Quad Q9650 (Ultima 90i cooled)
Mobo: ASUS P5K Deluxe
RAM: OCZ XTC PC8500 4x1 GB - 1066 MHz @ 5-5-5-15
Graphics: ZOTAC GeForce GTX 285 AMP! @ 700/2600 MHz
Storage: 1 TB WD Black + 500 GB WD 5000AAKS
OS: Windows Vista Ultimate x64 (genuine)
SMPS: Corsair HX 850W
Speakers: 'Sangram' modded Altec MX 5021
Cabinet: Lian Li A71F
Display: ViewSonic VX 2025 WM
Lucifer is offline
Old 04-03-2010, 11:48 PM   #3 (permalink)
Thanx ..Usually in these range Viewsonic does its best.But cant find anything now..
maximus is offline
Old 05-03-2010, 10:53 AM   #4 (permalink)
change is constant!!
khmadhu's Avatar
yeah benq is good .. but samsung gives still more clarity with high contrast ratio
samsung 23" LCD u can get at 11.4K.
Doesn't Digit teach you not to look at manufacturers quoted contrast ratios?
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 05-03-2010, 12:08 PM   #5 (permalink)
Cool G5's Avatar
Go for Dell S2409W.
Cool G5 is offline
Old 05-03-2010, 01:30 PM   #6 (permalink)
Super Moderator
asingh's Avatar
Yes that is an excellent choice...!
asingh is online now
Old 05-03-2010, 01:52 PM   #7 (permalink)
Originally Posted by Cool G5 View Post
Go for Dell S2409W.
+1. order it online.
Sam is online now
Old 05-03-2010, 08:51 PM   #8 (permalink)
Thanks guys for all your suggestion.. Well Dell S2409W is 3k higher than BenQ. Is that worth for that 3k increase? so i can see there is only two major brands in 24" range or is there anything in between this which offers better VFM?
maximus is offline
Old 05-03-2010, 09:32 PM   #9 (permalink)
yes. its worth 3k. maybe less if u order online. asigh can tell u better about it.
Sam is online now
Old 05-03-2010, 09:57 PM   #10 (permalink)
Cool G5's Avatar
@maximus - Yes, its definitely worth. I own it & I hope you read the review. A lot of guys over here will stand by my statement.
Cool G5 is offline
Old 05-03-2010, 10:19 PM   #11 (permalink)
Thanks a lot guys for guiding me.
So the deal is sealed, I'm going for DELL S2409W
But unfortunately i'm not able to find it on the dell site under 24" lcds
http://www1.ap.dell.com/in/en/home/m...=dhs&cs=indhs1
maximus is offline
Old 05-03-2010, 10:51 PM   #12 (permalink)
Super Moderator
asingh's Avatar
Just raise a query for any DELL model. You will get quotes for all of the ones available. I have known cases of BenQ coming out of the box -- dead pixels. Go for DELL.
You can read a review I put here.
Old 06-03-2010, 01:01 AM   #13 (permalink)
Another reason to go for Dell, now that I think about it, is the fact that it's a 16:10 display (aspect ratio) - better than 16:9 for everything except for movies.
Although I've not tested it. The BenQ I tested worked flawlessly and is probably equally good in terms of performance. Both are TN panels, which means they're equally un-hot for me...
Lucifer is offline
Old 06-03-2010, 11:19 PM   #14 (permalink)
^ S2409W is also a 16:9 monitor.
I would've bought s2409W if the price was same between G2420HD and S2409W. But since you are saying BenQ is 3K less than Dell's, go for BenQ. (It has been awarded Editor's Pick in this month Digit)
In Richie Street, BenQ G2412HD costs 11,100 and S2409W costs 12,750. Even then I had bought G2412HD for my friend.
I couldn't review about that monitor a lot, cause I didn't spend a lot of time with it. So far, with what I've seen, it is a very good monitor at this price range.
Also please note the luminance / brightness levels and actual contrast ratio, as they are the key to produce a breathtaking visuals. Of course, there are different things to be noted, but a bright monitor definitely becomes a treat to watch movies...
BTW, BenQ's G2420HD has a luminance of 288.9 cd/m^2 and Contrast Ratio of 562:1(Source: Digit) and S2409W has a brightness level of 242 cd/m^2 and a contrast ratio of 1001:1 (Source: Cnet).
NOTE: Digit uses Spyder 3 Elite and CNET uses Minolta CA-210 LCD color analyzer. And also they are under different testing conditions (room brightness etc., so i'm not sure whether the comparison is healthy one).
And of course, for 15K you would get a 22" 16:10 e-IPS monitor (2209wa) its waaay better than these two.
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
emmarbee is offline
Old 06-03-2010, 11:55 PM   #15 (permalink)
Thanks for all your advices..Finally i'm also a proud owner of DELL S2409W..The monitor is awesome.
For all those who are buying now.Now there is only marginal difference between Benq G2420 and Dell s2409.I got it at 11.9 @ SP Road Bangalore (of-course u need to be in a wanter's mode on each shop ).And I don't know if i could have got it cheaper by buying online.
And while taking into account of community members suggestion I can say easily that Dell is the clear winner in economic 24" LCD.
maximus is offline
Old 07-03-2010, 12:01 AM   #16 (permalink)
Cool G5's Avatar
Good to hear that.
The reduced price make it a very value for money monitor. Almost irresistible.
Enjoy the monitor.
Cool G5 is offline
Old 07-03-2010, 11:13 PM   #17 (permalink)
For 11.9K????????? That's a great deal. At that price, Dell is a steal
emmarbee is offline
Old 05-04-2010, 06:06 PM   #18 (permalink)
^Nice, you've done your homework. The CR of 1001:1 by CNET looks a bit fishy - TN panels rarely cross 700:1. 1000:1 is closer to where PVA/MVA get. Brightness level
(luminance) is another matter.
For us, the ambient light doesn't matter as we disable the backlight sensor. This is needed, because room brightness is a variable you want to remove from the equation.
The difference in luminance is also dependent on the value of brightness/contrast settings. Change these slightly and you will see a difference in luminance. We test at 2 settings - 100 percent brightness/contrast and 50 percent brightness/contrast.
Lucifer is offline
Old 06-04-2010, 06:45 PM   #19 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Check out LG 23" M237WA TV monitor. it is a bit costly (15K) but after you upgrade later you can use it as a standalone TV. Awesome value for money.
I work on it every day and watch IPL matches in PIP mode
Rollercoaster is offline
Old 07-04-2010, 11:31 AM   #20 (permalink)
Living to Succeed
ajayashish's Avatar
even 2309W from Dell is a good one to consider with resolution more than full HD
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
22" lcd monitor kartikkapo Hardware Q&A 30 24-06-2010 12:59 PM
Need help selecting 22 inch LCD monitor Red_Baron Hardware Q&A 11 26-02-2010 07:54 AM
Lcd vs crt monitor sanads Hardware Q&A 7 15-02-2010 12:47 PM
Which lcd monitor is best? GEEKCOMPUTER_GEEK Hardware Q&A 4 11-02-2010 11:46 PM
Plasma & LCD TV, what are they ... iMav TVs / Monitors 2 30-04-2007 11:49 PM
- by c4u
