Old 04-03-2010, 06:57 PM   #1 (permalink)
Default Cleaning your PC
hello guys ! once again i need your help to clear my doubt ........
my PC is getting very grimy and the innards of the case are full of dust.
I would like to know how to clean it WITHOUT FRYING MY components as I have already lost a RAM module once .
I also saw that PC Maintenance Guide forum ,.... but wouldn't dare do so, 'cause he was using brushes which might create a lot of static electricity !
So can anybody tell me how else can I do it ...??? can i get some compresses air cans in India. if so where??
thanks for the help !
daishi44 is offline
Old 04-03-2010, 11:12 PM   #2 (permalink)
Reviewerus Prolificus
Default Re: Cleaning your PC
Use a compressed air can, which you can pick up from a hardware store. I recommend using a cloth to wipe the grime off the cabinet innards and use the air can. You can also use a vacuum cleaner. Just use the blower and do not direct it too close to surface components on the mobo.
CPU: Intel Core 2 Quad Q9650 (Ultima 90i cooled)
Mobo: ASUS P5K Deluxe
RAM: OCZ XTC PC8500 4x1 GB - 1066 MHz @ 5-5-5-15
Graphics: ZOTAC GeForce GTX 285 AMP! @ 700/2600 MHz
Storage: 1 TB WD Black + 500 GB WD 5000AAKS
OS: Windows Vista Ultimate x64 (genuine)
SMPS: Corsair HX 850W
Speakers: 'Sangram' modded Altec MX 5021
Cabinet: Lian Li A71F
Display: ViewSonic VX 2025 WM
Lucifer is offline
Old 06-03-2010, 01:04 AM   #3 (permalink)
^Do post back how you did it. Maybe you want to send us a couple of pics before and after. We might find some use for them, or it'd be interesting for the forum itself.
Lucifer is offline
Old 08-03-2010, 06:52 PM   #4 (permalink)
thanks for the heads-up !
unfortunately iam having my exams over the next 20 days . so i will have to put off this adventure .. until April .
daishi44 is offline
Old 09-03-2010, 11:53 AM   #5 (permalink)
Lol, never mind. Post when it's done...
Lucifer is offline
A Guide To Cleaning Ur PC Inside-Out paranj Tutorials 36 16-03-2010 09:29 AM
Cleaning Fan Mohak QnA (read only) 1 12-11-2007 12:15 AM
CPU Cleaning Charan Hardware Q&A 18 17-10-2007 12:52 PM
XFCE not working...!!! vipul Open Source 2 19-05-2005 12:41 AM
- by c4u
