Old 03-03-2010, 05:42 PM   #1 (permalink)
nil_3's Avatar
Default Regular broadband disconnection
I have a BSNL Home 500 (dynamic IP) Internet plan with DLink DSL502T ADSL modem. I experience compulsory disconnection and automatic re-connection at an interval of 25-30 minute when the modem is configured in PPPoE/PPPoA mode. As a result, downloading gets stopped (but surprisingly IP address is not changed). But if I configure the modem in bridge mode with manual insertion of username & password, there is no disconnection even after running for several hours.
BSNL also recommends to configure the modem in bridge mode.
My question is: why is such compulsory disconnection in PPPoE/PPPoA mode?
I think, this disconnection is for re-dialing/re-inputing username and password and it is programmed to do this after an interval of 25-30 minutes. Please correct me if I am wrong. also, if that be so, then whether it is possible to change the program so that it will not disconnect at such a regular interval?
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 03-03-2010, 06:21 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Regular broadband disconnection
its BSNL problem not PPPoE/PPPoA mode problem.
I have been using PPPoE mode for years and never faced any such problem on my Airtel BB.
Do you use LAN or USB to connect modem??
ravi_9793 is offline
Old 03-03-2010, 09:05 PM   #3 (permalink)
nil_3's Avatar
If it is BSNL problem then how it is possible that there is not even a single disconnection in SIX hours each for 2-3 days configured at Bridge mode whereas regular disconnection in 25-30 minutes at PPPoE/PPPoA mode?
Tested in both LAN and USB; same problem.
Intel 945GNT MoBo.
1GB RAM.
nil_3 is offline
Old 03-03-2010, 10:49 PM   #4 (permalink)
Robin van Persie's Avatar
may be your router has some setting related to this..it should not happen....your router is at fault.
Robin van Persie is offline
Old 04-03-2010, 12:20 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
You should ask this question from BSNL customer care.
PPPoE mode don't have any such problem.
I have used PPPoE mode on MTNL and Airtel and never faced frequent disconnection problem.
Possible causes can be..
1) Modem hardware and firmware problem
2) Modem setting problem
3) Line problem.
Ask any of your neighbor using BSNL, if he is also facing similar problem.
Old 04-03-2010, 05:20 PM   #6 (permalink)
nil_3's Avatar
I also suspect this may be a farmware-related problem. But the problem is that DLink India stopped production of DSL502T modem and the last available farmware update is V2.00B01T01.ML.20050530. Farmware upgrade v2.00B12.AU_20070425 is available through DLink Australia website (http://www.dlink.com.au/tech/Downloa...oduct=DSL-502T). But a note on this upgrade says "NOTE: This firmware is only suitable for modems/routers distributed in Australia. If you bought your router outside Australia or New Zealand the firmware upgrade may damage your router and void the Warranty."
Can I safely upgrade my modem from the Australian DLink site.
Intel 945GNT MoBo.
1GB RAM.
nil_3 is offline
Scan Negatives on Regular Scanner! club_pranay Peripherals 8 03-10-2007 02:39 PM
How to: Free calls to regular USA, UK, Can etc. phones! Read it! Absolutely Amazing! nagarjun_424 QnA (read only) 56 20-01-2007 06:15 PM
A terabyte of data on a regular DVD? techtronic Technology News 1 09-12-2006 10:18 PM
Is it better to wait for HD-DVD/Blue-ray disk or go for regular DVD writers faraz_majidkhan Software Q&A 4 28-05-2006 02:13 AM
Scary font replaces regular in acrobat siriusb QnA (read only) 1 01-08-2005 11:08 PM
- by c4u
