01-03-2010, 10:59 AM
Require specification 4 Desktop i3
Hi friends,
I want to purchase i3 Desktop.Is there any model available from Dell,zenith etc?
I may consider assembled one but i dont know mb,ram etc.i want this pc 4 general use & should have on board graphics and slot 4 graphics card too 4 future requirement.My budget is 35k with 20"Lcd.
Thanks.
01-03-2010, 11:15 PM
Core i7 (nehalem) Owner
Re: Require specification 4 Desktop i3
please post ur querries here please (a request) ----> www.thinkdigit.com/forum/showthread.php?t=110397 there hv been too many posts on core i3 related rigs, so i wanna keep it clean and well oraganised, plz post in the link provided... a sincere request..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
04-03-2010, 06:30 PM
ashu888 your's above thread is 4 i7.i have inquired 4 i3 desktop.
anybody else would like to give me guidence?
04-03-2010, 06:50 PM
Simply a DIGITian
Intel Core i5 750 - 10k
GA-P55M-UD2 - 6k
Corsair 2GB DDR3 - 4k OR Transcend 4GB DDR3 - 5k ( For Dual Channel)
WD 500GB - 2.5k
CM Elite 310 - 1.5k
Gigabyte Superb 460W - 2.2k
L.G. GH22N DVD Writer - 1k
Miscrosoft Keyboard + Mouse Combo - Rs. 700/-
Benq G2020HD - 6k
Total = 33k
At a budget of 35k you can easily opt for Core i5.
If you want branded then Dell have this model on Core i3 within your budget.
http://www1.ap.dell.com/in/en/home/i...0_s241234in8~~
Though I personally suggest to go for the config given by me which is much higher config if nedded more fine tuned by other members.
- Read The Forum RULES First.
- Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
- Before Starting A New Thread Read The STICKY THREADS First
- Before Participating In Bazaar Section Read The BAZAAR RULES
04-03-2010, 07:11 PM
thanks.
Are these street prices?
is mb with pci slot for future graphics card supporting crossfire?
ram is howmuch mhz?
04-03-2010, 07:27 PM
Simply a DIGITian
Yup these are street prices. RAM's are 1333MHz. And yup the mobo supports Crossfire.
Check it yourself http://www.gigabyte.com.tw/Products/...me=GA-P55M-UD2
04-03-2010, 11:47 PM
visited gigabyte site, it seems that with suggested hardwares (P series mb) graphics card is needed.I dont want to buy it at present.so pl clarify.
05-03-2010, 06:50 PM
Simply a DIGITian
Yup it've inbuild (Integrated) graphics.
---------- Post added at 06:44 PM ---------- Previous post was at 06:32 PM ----------
Hey friend I'm really sorry. Did a big mistake. Thanks for pointing me out. Its h55 not p55
Take a look http://www.giga-byte.co.in/Products/...e=GA-H55M-UD2H
---------- Post added at 06:50 PM ---------- Previous post was at 06:44 PM ----------
Ok here is one more gr8 boards with USB 3.0 support http://www.giga-byte.co.in/Products/...ProductID=3365 - 7k
05-03-2010, 08:57 PM
dear friend,
I gone through gigabyte site.MB you have suggested is supporting graphics only when processor have integrated graphics.Does intel i5 750 has integrated graphics?
05-03-2010, 09:16 PM
Simply a DIGITian
Well......I'm not sure about this. Just wait for other members to come-in and reply.
05-03-2010, 09:20 PM
check the above site
05-03-2010, 09:23 PM
Simply a DIGITian
Checked..!! Thanks 4 the link
05-03-2010, 09:28 PM
At present I cant open the link.
but i have read somewhere that only i3 proce is having int graphics.
05-03-2010, 09:29 PM
Simply a DIGITian
Thats not true. Only selected models of Core i7 have integrated graphics.
05-03-2010, 09:36 PM
core i5-670, i5-661, i5-660, i5-650 have integrated graphics
i5-750, i5-750S do not have them
---------- Post added at 09:36 PM ---------- Previous post was at 09:32 PM ----------
core i5-670, i5-661, i5-660, i5-650 all cost above 10k
05-03-2010, 10:11 PM
Then I would like to go for i3.may I have spec 4 that?
05-03-2010, 10:37 PM
Simply a DIGITian
I dont know y u want to go for Core i3?? U can easily get Core i5 on that budget. Check out Gigabyte h55 based boards. I've posted the links in above post. Check 'em out.
05-03-2010, 11:05 PM
#19 (permalink)
I have to purchase graphics card at present if i opt 4 i5 which will increase my budget.
Suggest me GPU upto 4k.
It seems that if I have to add GPU then p series board will also do then tell me which series(p or h) I should opt.
06-03-2010, 03:00 PM
#20 (permalink)
[/COLOR]if you are building the rig for gaming then i dont recommend a 4k graphics card
you can easily get a good graphics card with amd based rig
06-03-2010, 03:48 PM
#21 (permalink)
+1. if gaming 1st priority , throw away your idea of i3. get a AMD Athlon II X4 @ 5k + a sub 6k crossfire supporting mobo. & a midrange graphics card like HD5670 or HD5750. @ 35k, u'll get a far better AMD rig with good mobo & fast proccy. but Intel wil give u i3 + a crappy H55 @ 6k (intel original), that doesn't even support crossfire  .
if u want an AMD rig for gaming with crossfire support. do let me know. wil configure 1 for u.
06-03-2010, 04:07 PM
#22 (permalink)
Thanks.Gaming is not my priority,Autocad appli and Minor video encoding are my req.
Does AMD supports DDR3 RAM?I dont want to go 4 ddr2.according to my req you may give me spec.
06-03-2010, 05:12 PM
#23 (permalink)
yes, AMD surely support DDR3. ok heres a good config for 35k:
Processor: AMD Athlon II X4 630 2.8Ghz: 4.9k
Motherboard: Biostar TA785G3 HD: 4.3k //support 140W cpu & 128Mb DDR3 onboard//
Ram: Transcend 2 X 2Gb DDR3-1333Mhz C9: 5.5k
Hard Disk: WDC Blue 500Gb: 2.3k
Graphics Card: Sapphire HD5670 512Mb GDDR5: 5.3k
Optical Drives: LG 22X DVD SATA: 1.1k
PSU: FSP Saga II 400W: 2.2k
Cabinet: NZXT Gamma: 2k
Monitor: BenQ G2020HD 20" LCD Monitor @ 6.8k
Keyboard Mouse: Logitech Internet Pro Desktop: Rs. 0.6k
Total: 35k. these are real market prices so the total should be below 36k.
ok if u want crossfire, change this:
Motherboard: Biostar TA790GX A3+: 5.5k //affordable crossifreX//
06-03-2010, 05:52 PM
#24 (permalink)
Are Biostar boards reliable?here at my city, dealer recom Gigabyte & ASUS.
For RAM, what is meant by c9?pl explain.
Thanks 4 nice config.
06-03-2010, 06:32 PM
#25 (permalink)
they are reliable. most choose Asus & Gigabyte & Msi cause they more famous, but bio are not bad at all. they make lots of boards for AMD as well as for Intel, but you need to choose the right one.
C9 is the latency of ram. read here.
welcome mate. nice helping you out.
06-03-2010, 08:12 PM
#26 (permalink)
Simply a DIGITian
I think the OP doesn't need an gaming rig. That's why I suggested him an Core i5 rig.
@OP Look if you go for H55 based boards(I've posted the link of 2 h55 based gigabyte boards avobe) you don't need any graphics card. It've integrated graphics.
If you want to go for P55 based boards then you need graphics card. As for your query of graphics card within 4k, 9600GT 1GB - 4.2k(if you can afford the .2k more) otherwise go for 9500GT 1GB - 3.5k
+1 to Sam.Shab's config if you've changed your mind and want to go for gaming rig.
And for your query : Ya you can opt for biostar boards they are reliable. If you still dont want to go for it, you can go for Gigabyte MA785GMT-U2SH - 6k.
But as you said gaming is not your requirement, video encoding and decoding will be better in Core i5. Well lets see what other member says. But if you want gaming cum encoding-decoding rig @ this budget AMD is your option, and +1 to Sam.Shab's config.
06-03-2010, 09:30 PM
#27 (permalink)
h55-m-ud2h this mb supports graphics only when cpu has it.pl confirm by visiting & see point no:10 on the giga site.
this shows that i have to install GPU WHICH will increase my budget for i5 750 rig.
help from any member will be apreciated.
06-03-2010, 09:44 PM
#28 (permalink)
Simply a DIGITian
Ya you r rite. Sorry 4 the misconceptions. Go with sam's config.
06-03-2010, 09:57 PM
#29 (permalink)
core i5 wil really help encoding. i agree. & adding a cheap 9500gt 512Mb ddr2 wil make the rig complete. but the problem is if OP tries game on this config, it'll suck. it'll badly bottleneck the proccy. & also i5 750 wil up the total cost of PC above 40k. maybe 45k if low cost board not available.
i just added the HD5670 512Mb cause OP mentioned me wil be using pc for gaming as well. will aid in graphics related work as well.
yup. any board based on Intel H55/H57/Q57 chipset wil support graphics if the proccy have Intel HD Graphics inbuilt. but if u do graphics related work, u be better suited by 4 physical cores rather than 2 living cores & 2 non-living ghostly cores. i mean Hyper Threading.
though i3 wil OC past 4Ghz easily. may reach 4.5Ghz if proper cooling is provided. whereas X4 630 wil never touch 3.5Ghz how much voltage you apply. so choice is yours.
06-03-2010, 10:24 PM
#30 (permalink)
Simply a DIGITian
Thanks sam and nihu for pointing out my mistake.
+1 to sam's config.
