Old 28-02-2010, 10:01 PM   #1 (permalink)
arian29's Avatar
Arrow laptop with no operating system?
Is it possible to purchase a brand new laptop with no operating system? If yes.. what all options do i have..
arian29 is offline
Old 01-03-2010, 05:26 AM   #2 (permalink)
CG Artist++
Hsakarp_kahtap's Avatar
Default Re: laptop with no operating system?
Yes, day before yesterday one of my friend purchased a Dell's laptop for 33k with dos .
AMD Phenom 1055T @3.5 GHz|| MSI 890 GXM- G65||12 G.B G-Skill Ripjaws 1600 MHz || Segate 500 GB*2 + 1T.B|| CM 690 II Advance|| Cosair VX 550|| MSI NGTX 460 || APC 650 || WD MY Passport 500 G.B USB 3.0 ||
Hsakarp_kahtap is offline
Old 01-03-2010, 09:30 AM   #3 (permalink)
arian29's Avatar
can you pls tell me from where n how.. i don't see any option on dell website
arian29 is offline
Old 05-03-2010, 11:51 PM   #4 (permalink)
Bada Is Doing Fine
NeptuneTech's Avatar
Lightbulb Re: laptop with no operating system?
well it is possible that you can purchase a laptop without an operating system. doing so, you might have to pay less,just the OS cost maybe deduced from the total price....and later you can install an OS of ur choice....
For installation of an OS:
FIRST...CHANGE BIOS SETTINGS AND BOOT THE COMPUTER VIA CD/DVD DRIVE AND THEN INSTALL USING THE GIVEN INSTRUCTIONS...
NeptuneTech is offline
Old 06-03-2010, 06:42 AM   #5 (permalink)
Except dell, most other laptop vendors like hp and lenovo offer a lot of laptops only without OS... But if you choose a laptop with preinstalled OS specified, I doubt if they will reduce price and send it without OS...
Arun
sakumar79 is online now
Old 10-03-2010, 03:09 AM   #6 (permalink)
Tech'ing life seriously!!
sude's Avatar
Well yes arian..
its possible.. most low (entry level) laptops now a days come with "FreeDos".
You are most free to install any OS according to the hardware.
FYI, I bought Compaq Presario C783tu a year ago. it came with FreeDos.
-SUDE
Hi! Any1 pursuing PG from SCDL (Symbiosis Distnce Learnin) frm Bangalore? If yes PM me. We cn form a study group (on weekends). Ths wil b mutually beneficial!
Rgds. SUDE | www.lifeethiquette.co.nr
sude is offline
cloud operating system sudhansagar Open Source 5 30-04-2010 06:02 PM
Operating System inside a browser TheHumanBot Tutorials 14 15-02-2010 06:41 AM
Physical Memory Limits of Windows XP 64 Bit Operating System Gauravs90 Tutorials 11 05-10-2009 04:59 AM
Vista won't load after XP Reinstall d Software Q&A 9 07-08-2006 11:11 AM
- by c4u
