Old 26-02-2010, 12:24 PM   #1 (permalink)
Default AMD / intel - best VFM???
need 2 systems....
needs...
1.
ddr3 + raid 5 + dual gbps lan or 2 pci slots.
mobo + proc = 12000 budget.
2.
ddr2 + gbps lan
mobo + proc = 7000-8000 budget
needed best vfm for both..
thanx
angel
The Day Walker! is offline
Old 28-02-2010, 12:49 AM   #2 (permalink)
Default Re: AMD / intel - best VFM???
i inquired my dealer here ...
and got the following prices.....
1.
intel i3 530 + intel mobo = 12000 (ddr3)
vs
amd phenom 2 x4 925 + asus m4a78t-e mobo = 11900 (ddr3)
which is better in performance.... as these 2 suits my budget....
2.
intel c2d 2.93 + asus p5kpl amps mobo = 8250
vs
amd phenom 2 x2 545 + asus m2n68 mobo = 7300
or any other that u pals suggest.... that would help..
thanx
angel
Old 28-02-2010, 01:36 PM   #3 (permalink)
Joker
Posts: n/a
the AMD ones are more VFM.
however, in config 2, you can go for Phenom x2 555 and unlock it.
Old 28-02-2010, 02:15 PM   #4 (permalink)
1.
vs
2.
vs
thanx
angel
the 78t-e is based on 790Gx. better get Athlon 630 + ASUS M4A785TD-V EVO based around 785G. 2 times better graphics than i3's. & asus utility wil automatically OC the graphics. get i3 only if u wish to OC the processor
Sam is online now
Old 28-02-2010, 06:39 PM   #5 (permalink)
since the pcs r for my office so no gfx card...or anything.....just plain...
14hrs photoshop usage..... thats it....
no need for better grafix.... as nothing else will be started ont he pc...other then photoshop and acdsee...
thanx
angel
Old 28-02-2010, 09:05 PM   #6 (permalink)
thanx
angel
if for office, then get the following :
Athlon II X4 620 or 630 if price diff low.
BIOSTAR TA785G3HD or Biostar TA785G A3
4Gb DDR3 ram.
HDD of capacity as u wish.
Zebronics bijli with default PSU.
Sam is online now
Old 01-03-2010, 07:14 PM   #7 (permalink)
Yup the AMD ones are more VFM
Athlon II X4 630/635
BIOSTAR TA790 or ASUS 790 based board[go am3 based board]
4Gb if DDR3 ram
Zebronics bijli with default PSU..
beelzebub360 is offline
Old 01-03-2010, 11:14 PM   #8 (permalink)
is athlon 2 x4 630 better then amd phenom 2 x2 545????
if yes then illl go 4 it...adn wot abt the 1st config.....
the pc will act as a storage server....
thanx
angel
Old 01-03-2010, 11:52 PM   #9 (permalink)
thanx
angel
X4 630 is better for longer run, specially if used for photoshop. X2 545 is good but 2 cores won't help much.
as for 1st config, let me ask someone else help u out here.
Sam is online now
Old 02-03-2010, 01:57 PM   #10 (permalink)
is athlon 2 x4 630 better than amd phenom 2 x2 545 - YES
but if u want to do overclocking
go for Phenom X2 555 & over clock it..[enable disabled core then it will hv 4cores]
but if ur going to Multitask go for i3 or i5 based system
else 630 is AWsum
Old 02-03-2010, 03:29 PM   #11 (permalink)
k..pals...
then ill go for athlon 2 x4 630, in my second config...
now need some help in my 1st config......
thanx
angel
Old 03-03-2010, 01:22 AM   #12 (permalink)
config for my server base pc...
storage access.... will do a raid 5 + dual lan...
should i go for i3 530 or amd phenom 2 x4 925
thanx
angel
Old 04-03-2010, 09:52 AM   #13 (permalink)
hey guys i need 2 buy my server based pc by 2moro...
so kindly help. its urgent...
thanx
angel
AMD VS INTEL laptops ramkumar.research Laptops and Netbooks 16 17-03-2010 11:38 AM
amd k10(agena) beats intel QX 6800 ssk_the_gr8 Technology News 25 29-04-2007 08:27 PM
AMD, Intel duel goes slash ankitsagwekar Technology News 5 31-03-2007 12:27 PM
AMD Vs. Intel : AMD Challenge King_Niral CPU / Motherboards 19 08-10-2005 02:35 PM
Intel Insecure with AMD ? indro CPU / Motherboards 7 21-05-2005 04:51 PM
- by c4u
