Old 26-02-2010, 03:03 AM   #1 (permalink)
Smile Tight Budget Core i7
Hello to all of yo...........:-P:-P:-P
I am planed for building a system for almost every thing i like.Which i m likely to buy within 2/3 days (Bangalore SP Road)
And most of it i have made a configuration for the same after reading at many places and here in the forum also.
My Budget is fixed at 55,000 (May Be a bit flexible but not much)
Specs
Core i7 920
Msi X58 Pro
Corsair XMS3 1x3GB
ATI 4870/4890
24'' Full HD Dell/Benq/AOC
1.5/1 TB seagate 7200.12
Corsair 450w PSU
Lest Bothered About -----
Cabinet (any will do)
Mouse/KeyBoard ----- (Fixed Rs 300 each Logitech)
Ups any..........
Please suggest me if u have any changes in the spec.
I Am confused of the following......
MotherBoard if any other cheap option available.
Graphics card Other Best options.(Brands To Go For)
A good Monitor ( i like thin outer bracket of monitor)
Good enough power supply ( i will give this Graphics card to my brother and upgrade with 5/6 series ATI when it will get affordable)
If i opt for a DDR3 1600 MHZ against 1333 MHZ how performance is going to affect in real world.
Does This MSI board support 1600 MHZ or need overclock to work with.
Also is it wise to buy a 1333 MHZ and then overclock to get 1600 MHZ.
Also please suggest a good enough cabinet....
tnx............. BOZX
bozx is offline
Old 26-02-2010, 10:34 AM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: Tight Budget Core i7
hmm, seems like a good enough build..
(sorry editing my post again as i missed ur budget of 55K) its a really tight budget but i'll try to fit in all the components....
Processor: Core i7-920 (2.66Ghz stock speed)
Rs. 15K (it will be hard to fit in a core i7 proc, if u cant then go in for a core i5 processor as i DO NOT knw by HOW much? will u be able to extend ur budget...
Motherboard:Gigabyte UD5 )this is a gr8 bang for ur buck if u NOT willing to OC or OC to a small limit) (for heavy OCing, Evga X58 board is available but it maybe outta ur budget as it will cost u 21-22K
Rs.16K
RAM: Corsair TR3X3G 1333 C9 (3GB Kit) (3 RAM modules each working @ 1333Mhz) (save money on RAM and instead of goin for 1600mhz modules, spend those money on a better GPU)
(The RAM u hv mentioned XMS3 is a 4GB kit i guess with 2x2GB RAM modules) its better to go with 3kit RAM modules to utilize the tri channel memory support of the Motherboard in multiples of 3 like 3gb,6gb,9gb,12gb,,,etc...
Rs.7.5K
GPU: an ATi based gpu will get into ur budget so a 4870/4890 wud be better
LCD: a 24" will cost u around 14-15K, whereas a 22" LCD (FullHD) Will be under 9K (here again, i wud say go in for a 22" LCD and spend the rest money on a better GPU)
a 22" Samsung FullHD 2233SW (1920x1080) with DVI will cost u approx. Rs.8K (or jus under that)
HDD: a 1TB hdd (sata-2 7200rpm) is more than enough to hold all ur games, movies and other things..go with WD please (i jus dislike seagate..lol..)
PSU: get a Corsair 650TX PSU (as u said u will be upgrading to a better gpu in future)
Cabinet: Coolermaster CM690 (dnt ignore the cabinet as it will house ur Components and will also regularize air flow so a better cabinet is a must) will cost u 4.2k
ups: (jus dnt say any USP dude..its important as well) as the PSU (Corsair 650TX) is an ACtive PFC type of PSU, a pure sine wave output UPS is required (though they are costly as compared to stepped/modified sine wave UPSes), go in with APC's "SMART UPS" range of UPS (their "BACK UPS" range is a stepped sine wave UPS and NOT pure sine wave)
in general, a ACTIVE PFC type of PSU requires a PURE SINE WAVE UPS (keep this in mind)... a 900VA-1000VA UPS will be jus fine..
but as per ur 55K budget limit, this UPS wont come in ur budget i guess it will cost u 10K alone
Cheers n e-peace.....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 26-02-2010, 12:10 PM   #3 (permalink)
Hi,
I am building a very similar PC with a bit different constraints. I reside in east delhi. My budget is 45 k. Already have a monitor, keyboard and mouse.
CPU - Core i7 920
Motherboard - Msi X58 Pro
RAM - Transcend 2GB DDR3 1333MHz C9
Graphic Card - ATI 5770 (XFX)
Hard Disk - 500 GB seagate 7200.12
Cabinet - Cooler Master Centurion 690
PSU - Coolermaster - 650
I have came across a very peculiar problem. Retailers all across the Nehru place are saying that they can't sell Core i7 920 loosely to me and it has to be packed with the motherboard from Intel too. So, this implies that I can't go for MSI motherboard which I so desperately want to.
And peculiar enough I am not able to find MSI x58 motherboards anywhere in Nehru Place exactly for the very same reason that i7s are not available lossely.
Can anyone help me out in this problem? Also, any suggestions would be welcome.
Thanks....
mohit_ is offline
Old 26-02-2010, 12:22 PM   #4 (permalink)
Both of u guys, can u please post ur querries here please (a request) ----> www.thinkdigit.com/forum/showthread.php?t=110397 there hv been too many posts on core i7 related rigs, so i wanna keep it clean and well oraganised, plz post in the link provided... a sincere request..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 26-02-2010, 12:24 PM   #5 (permalink)
I am the night! I am....
vickybat's Avatar
@ bozx
Buddy for your budget a core i5 based config is ideal. BELOW i have listed the components so have a look....
Core i5 i750 2.66GHz @ 10k
MSI P55 CD-53 @ 7.5k
Corsair 4GB DDR3 1600MHz C9 Titanium @ 5.8k
NZXT Gamma cabinet @ 2k
Seagate Barracuda 7200.12 1TB @ 4k
LG 22x DVD @ 1.1k
BenQ 22" G2220 FULL HD LCD Monitor @ 8k
Corsair VX550W @ 5.2k
Sapphire HD5850 1GB GDDR5 @ 15.8k
Total = 59k
If you want to cut down the budget then opt for radeon 5770 @ 10k along with corsair vx450 @ 4k but the above one is the best for you.Haven't mentioned keyboard and mouse so go for any logitech or microsoft combo.
If you want to go for i7 920 then stick with the msi x58pro as its the cheapest x58 board available out there with a lot of overclocking features.
@ mohit_
The vendor is lying. The i7 920 doesn't come bundled and can be used with any x58 board.He must have ordered some bundles and is lying in order to sell them and clear stock. Look or some other vendor else try ordering online.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 26-02-2010, 12:24 PM   #6 (permalink)
not a problem ashu..moving it now...thanks
mohit_ is offline
Old 26-02-2010, 12:26 PM   #7 (permalink)
Please mohit, dude post ur query in the above link, i jus wanna keep all the core i7 related queries in one Master thread so tat its easy for all of us to hv a discussion on a common platform without the need for new users as well as old buddies searching the entire forum... hope u understand..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 26-02-2010, 10:43 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Thanks....
That is the biggest LOAD of bull sh$$ I have heard. Those dealers are just a$$-holes out at Nehru Place. Give me a day or two, will get you SMC Internationals Number from Nehru Place. They are good. They deal with high end parts.
Else you can order from Lynx-India. Also you want MSI since you will OC..?
---------- Post added at 10:43 PM ---------- Previous post was at 10:21 PM ----------
PM'ed you SMC Internationals address and phone numbers.
asingh is online now
Quick Look at XFX nvidia 7150 Mobo for C2D supporting OC Choto Cheeta Reviews 46 08-06-2008 12:57 PM
Intel Core 2 Duo E8500 [wolfdale CPU] released and tested. desiibond Technology News 8 05-03-2008 12:28 PM
Re:Recommend a PC config budget 60k !! kaps_2222 PC Components / Configurations 1 02-02-2008 11:43 PM
How is Pentium 4 3.2GHZ with HT diffrent & faster than Core 2 Duo and Pentium D. I Do Not Have A Username. CPU / Motherboards 12 22-11-2006 09:26 PM
Intel Pentium D 2.80 Ghz reviewed (dual core) mohit CPU / Motherboards 1 27-05-2005 02:11 PM
- by c4u
