Old 25-02-2010, 11:58 PM   #1 (permalink)
Default EES is turned off Error
While working I am getting this below mentioned error so pls help and why I am getting this error.
WARNING: EES is turned off !! Please use EES application to turn it on again. Press any key to continue' and pc gets restarted automatically.
PC Config
Dual Core Processors :2.6 Ghz
Motherboard : Gigabyte G31
Ram : 2 GB
HDD : 320GB
girishrn is offline
Old 02-03-2010, 06:27 PM   #2 (permalink)
Treatment in progress...
mukherjee's Avatar
Default Re: Gigiabyte G31
wats the exact model no of ur board?
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline
Old 02-03-2010, 08:44 PM   #3 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
EES is Gigabyte's Energy Saver. Enable USB Keyboard and USB Mouse from BIOS if you use them. Otherwise Turn on Energy Saver if you ever have turned them off from BIOS and Windows(Whichever applies in your case)
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 04-03-2010, 12:09 AM   #4 (permalink)
Hi Krishanandu,
If I uninstall energysaver, it will work / i will face any problem.
girishrn is offline
Old 04-03-2010, 12:18 AM   #5 (permalink)
Simply a DIGITian
I really don't have any idea. Give it a try.
Old 04-03-2010, 12:26 AM   #6 (permalink)
Super Moderator
asingh's Avatar
@OP:
Reset the BIOS to default, and commit it. Also any OC/system monitoring software(s) that was bundled/slip streamed with the driver packages and/or motherboards discs -- uninstall them.
asingh is online now
Old 04-03-2010, 12:37 AM   #7 (permalink)
Simply a DIGITian
^+1
Gigabyte's energy saving feature is one of its unique feature, I don't know why you don't intend to use it.
- by c4u
