Old 25-02-2010, 10:35 PM   #1 (permalink)
kartikkapo's Avatar
Default 22" lcd monitor
Hello guys,
I want to buy a LCD monitor. So I Want to ask the experts out here for some good
suggestions. As i will be switching from a 17" CRT to a 22" LCD.
1> My budget is not more than 15,000/-
2> I will prefer a Matte screen over a glossy screen.. coz it puts less strain on eyes. though I'm aware that glossy screen has richer picture quality. (but i can always go for a glossy screen if i dont get a better one in matte).
3> Are 4:3 ratio panels better than the 16:9 ratio panels? (4:3 has more pixels than 16:9)
4> These days LED monitors are being introduced and may be they get over in the market very soon. are there any good led monitors in this budget? Is it better to buy a LED monitor rather than LCD one?
5> These are the ones I have selected...
DELL
Alienware OptXTM AW2210 21.5” Full HD Monitor Rs.9775/-
Dell SP2309W: 23" Rs.15295/-
AOC
AOC 2218ph 22"
AOC 2236Vw 22" FULL HD LCD Monitor @ 8.7k
ACER
Acer V233H 23.6" FULL HD LCD Monitor @ 10.6k
BENQ
BenQ 22" G2220 FULL HD LCD Monitor @ 8k
BenQ 22" v2200 eco @ 12990
SAMSUNG
Samsung T220 22"
Samsung 2233sw 22"
Thanks
kartikkapo is offline   Reply With Quote
Old 26-02-2010, 07:41 AM   #2 (permalink)
Its Best only if its open
ankushkool's Avatar
Default Re: 22" lcd monitor
for 14k u can go for AOC 24" LCD!
ankushkool is offline   Reply With Quote
Old 26-02-2010, 09:57 AM   #3 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
yaa right, if ur budget is 15K, u can easily afford a 24" LCD..
i personally hv the samsung 2233sw wich is a gr8 LCD for movies and gaming too... but yes u shud go for a 24: LCD with tat budget..
---------- Post added at 09:57 AM ---------- Previous post was at 09:55 AM ----------
for the record, even the so called "LED" monitors are jus LCD backlit monitors, so its one and the same mostly, not a vast difference...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline   Reply With Quote
Old 26-02-2010, 06:08 PM   #4 (permalink)
kartikkapo's Avatar
well i raised my budget to 15k just in case if i would buy dell sp2309w. and i don't have a graphic card, so do u think 24" will work smoothly. Didn't gave a thought to buy 24".
Old 26-02-2010, 07:44 PM   #5 (permalink)
No Graphics card and wanna go with 24" LCd..//wel it will be a lot of strain on the CPU and onboard video chip...wats ur PC config...???
I wud say stick to 22" LCD in the absence of a GPU, as on board graphics is NOT on par with a discrete gpu, no way..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 27-02-2010, 01:31 AM   #6 (permalink)
kartikkapo's Avatar
I have a P4 with 2gb RAM.
yes i'm fine with a 22" screen but which one should i go for.. wide screen or square screen?
Old 27-02-2010, 10:18 AM   #7 (permalink)
i hv had a p4 based system b4 with 2GB RAM and on board graphics...and i can say tat my 19" LCD workds wonders with on board graphics....
so a 22" LCD shud work easily, (i hv doubt on 24" LCD)...so u better go with 22" and a wide screen...NOT a square screen..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 27-02-2010, 03:17 PM   #8 (permalink)
kartikkapo's Avatar
gr8, so help me choose one from these options.. or any other model u have in mind...
DELL
AOC
AOC 2218ph 22"
ACER
BENQ
SAMSUNG
Samsung T220 22"
Samsung 2233sw 22"
Old 27-02-2010, 05:17 PM   #9 (permalink)
kartikkapo's Avatar
Please guys tel me a gud lcd monitor (preferably with matte screen) which i can cherish about for a long time.
Old 27-02-2010, 09:02 PM   #10 (permalink)
I M A *STAR*
saqib_khan's Avatar
I would suggest Samsung 2233SW or P2350. Compare these both and then choose the one from them. BenQ G2220 is also a good choice but budget is not your problem therefore I would recommend Samsung.
Blogging at:
Technostarry
saqib_khan is offline   Reply With Quote
Old 04-03-2010, 03:42 PM   #11 (permalink)
kartikkapo's Avatar
Question Re: 22" lcd monitor
hello guys..
I'm going to buy a monitor in 2-3 days...nd i'm getting
> Samsung 2233sw @ 8.7K
> Samsung p2350 @ 10.7k
what do you think will be a better and wise choice...?
thanks
Old 04-03-2010, 09:52 PM   #12 (permalink)
ankushkool's Avatar
According to most reviews AOC monitors are better!
Old 06-03-2010, 11:29 PM   #13 (permalink)
kartikkapo, check whether you can get 2209WA from anywhere. If available, grab it immediately. The best price for it would be 14K, but you can go till 16-17K.
BTW, it's the best 22" monitor for its price range.
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
emmarbee is offline   Reply With Quote
Old 09-03-2010, 12:52 AM   #14 (permalink)
kartikkapo's Avatar
Thumbs up Re: 22" lcd monitor
So.. the hunt has finally been ended guys, with my new purchase of the "SAMSUNG P2350".
The 23", matte screen, classic black monitor. With touch sensitive buttons.. and a sheen sleek body..
apart from the design and built, the monitor has a 2ms respomse time and 50,000:1 contrast ratio as stated by the company. the picture quality and the screen size is briliant (almost to drool over). For me a person who used to have a SAMSUNG 17" monitor, this purchase is the best. Hava a look at the pictures for some visual impact..
__________________________________________________ _____
Shot at 2010-03-08
Shot at 2010-03-08
Shot at 2010-03-08
Shot at 2010-03-08
Shot at 2010-03-08
Shot at 2010-03-08
Shot at 2010-03-08
Shot at 2010-03-08
__________________________________________________ _______
Thank You guys for all your suggestion... You are great ppl out there to help...
Old 19-03-2010, 04:28 PM   #15 (permalink)
Hi kartikkapo, how much did you pay for the monitor?
Also, you mentioned in your first post that Dell OptX is available for Rs.9750, can you please tell me where can I buy it from in Delhi?
hardeep1singh is offline   Reply With Quote
Old 19-03-2010, 09:38 PM   #16 (permalink)
kartikkapo's Avatar
Call Dell India and they will tell you the price and the best offer they can give you. As for me i called the Dell in gurgaon. But the same lady told told me that don't go for the alienware optx as the users have complained about dead pixels.. rest is up to u. you can get the number on dells website.
Old 19-03-2010, 09:55 PM   #17 (permalink)
Thanks for your reply. I've recently returned a P2250 LCD monitor to Samsung as it had screen problems and now I'm searching for another monitor to buy. I can't seem to find anything better so I might have to go for Samsung again. Can you tell me how much did you pay for your P2350?
Old 22-03-2010, 11:12 AM   #18 (permalink)
kartikkapo's Avatar
I bought it for Rs.10,600/-
Old 23-03-2010, 08:24 AM   #19 (permalink)
Thanks for your reply kartikkapo but I ended up buying a Dell G2410 LED monitor. It has a 1,000,000:1 DCR and a 5ms black to white response time.
http://www.dell.com/content/topics/t...=us&l=en&cs=04
Old 23-03-2010, 05:32 PM   #20 (permalink)
sam_1710's Avatar
Great Buy! Congrats.
Can you tell how much it cost?
C2D E8400, MSI P45 Neo-F, Sapphire HD4850, Dell 2409W, OCZ 2*1GB RAM + 1*2GB Transcend + 1*1GB Transcend , Seagate 1TB + 2*Seagate 80GB, 600W SMPS, APC 600VA, Creative EP630, Sennheiser HD202 :)
sam_1710 is offline   Reply With Quote
Old 23-03-2010, 07:05 PM   #21 (permalink)
I got it for Rs 15,000.
Old 23-03-2010, 07:19 PM   #22 (permalink)
sam_1710's Avatar
Oh I see..
I'm in a dilemma..
Which one should I go for.. G2410 or the 2409??
Old 23-03-2010, 08:04 PM   #23 (permalink)
Oh I see..
I'm in a dilemma..
G2410 is an LED. 2409 is not. Check the DCR you'll see a huge difference.
Old 24-03-2010, 04:25 AM   #24 (permalink)
Point Blanc
G2410, also nice buy OP and hardeep
acewin is offline   Reply With Quote
Old 17-04-2010, 03:02 AM   #25 (permalink)
ankushkool's Avatar
Why is that various reviews and comparison show that AOC monitors are better but no one suggests them!!!
Old 17-04-2010, 06:52 AM   #26 (permalink)
Revolution's Avatar
@kartikkapo
Hey man every thing looks cool except ur white keyboard.....
Revolution is offline   Reply With Quote
Old 20-04-2010, 05:13 PM   #27 (permalink)
avichandana20000's Avatar
i will also go for a 22" monitor from crt 15". Budget is 10000
My proccy is AMD PHENOM II X4 955 BE & mobo ASUS M4A78T-E 790GX.
No graphics card attached. My list :
DELL ST2210
AOC 2236 VW
pls suggest.
avichandana20000 is online now   Reply With Quote
Old 22-04-2010, 06:11 PM   #28 (permalink)
Finally bought aoc 2236 vw for 7300/- . Cool monitor.
Old 18-06-2010, 12:05 PM   #29 (permalink)
hey the samsung 2350, is that a monitor tv?? like does it have an onboard tv tuner?
jake4642 is offline   Reply With Quote
Old 18-06-2010, 07:13 PM   #30 (permalink)
for 15k dell 2209wa is awesome as it is a E-IPS , the cheapest avbl.
congrats to both op and hardeep.
aby geek is offline   Reply With Quote
Need help selecting 22 inch LCD monitor Red_Baron Hardware Q&A 11 26-02-2010 07:54 AM
Lcd vs crt monitor sanads Hardware Q&A 7 15-02-2010 12:47 PM
Which lcd monitor is best? GEEKCOMPUTER_GEEK Hardware Q&A 4 11-02-2010 11:46 PM
Dell E228wfp 22" Lcd Monitor vivekbabbudelhi Reviews 52 04-09-2008 05:08 PM
Please suggest 20" or 22" LCD Monitor for gaming under 15K codehammer Hardware Q&A 3 03-07-2008 01:04 AM
- by c4u
