Old 25-02-2010, 02:38 PM   #1 (permalink)
Default No 32 bit games on intel i5 (true or false)
i went to buy Acer Aspire 5740G in a shop but the shop owner told me that it comes with i5 processer which do not support 32 bit software (read here games), he also said that XP is also incompatible with i5 core (i series). now i am very confused since i like to play retro games like Rise of nations, warcraft, age of empires, halo. which i suppose are 32bit games.
So please help.
join my orkut community to download latest movies, music & games here's the link to view it http://www.orkut.com/Community.aspx?cmm=38665088
Blackfire is offline
Old 25-02-2010, 03:24 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: No 32 bit games on intel i5 (true or false)
The shopkeeper is an idiot.
1. i5 will support 32 bit and 64 bit.
2. XP will run on i5 socket.
asingh is online now
Old 25-02-2010, 03:24 PM   #3 (permalink)
change is constant!!
khmadhu's Avatar
never mind u r game will run on 32/64 bit platform
I am sure that xp will support these processors, becoz these i series are nothing but core 2 duo/quad core processors only (but enhanced).
If you really wanna think, try to think from Atom to Universe!!
cpu: core i5 2500k, mobo: DP67BG, RAM:Corsair 8GB(4x2) 1600 Mhz, XFX HD 5770, 1TB seagate 6Gbps 7200 rpm , SAGA II 500W
khmadhu is offline
Old 25-02-2010, 03:30 PM   #4 (permalink)
AMD - Aaja Meri Darling
^ yep, most of the softwares which are general purpose run on either 32 or 64 Bit OS. Only stuff like some antiviruses or firewalls have a 32 bit / 64 bit version separately.
You might want to install 32Bit windows 7 / 64 bit on such a system, or go with plain 32bit XP. Don't install 64bit XP since updates are erratic and its not that stable.
Also the shopkeeper is an idiot.
The recent generation of processors support both 32/64 Bit OS's without any hassles.
AMD Athlon II X4 620 | ASUS M4A785TD-V EVO - 785G
Xeno is offline
Old 25-02-2010, 04:16 PM   #5 (permalink)
I M A *STAR*
saqib_khan's Avatar
Ehh..now he(shopkeeper) truly is truly an idiot. Your games and OS (XP) will run on it with no problem. I would recommend to use Windows 7, on such a high end lappy.
Blogging at:
Technostarry
saqib_khan is offline
Old 25-02-2010, 04:52 PM   #6 (permalink)
Super Moderator
asingh's Avatar
No need to install two OS. Regarding XP/Vista/Windows7:
The 64BIT versions have WoW emulator (Windows on Windows) which seamlessly run the 32BIT application on the 64BIT application.
XP 64BIT is stable. I used it for 1.5 years. No issue.
Old 25-02-2010, 07:05 PM   #7 (permalink)
Legendary Darknight
latino_ansari's Avatar
these shopkeepers are useless fellas... They even don't know stuff about their own product... Just imagine who will buy i5 processors if it doesnot supports 32bit games.. Go ahead buy the laptop... nice one and don't worry about all that stuff which he told u...
latino_ansari is offline
Old 25-02-2010, 11:52 PM   #8 (permalink)
Ahh i didnt mean that the slash meant "either" of the two.
I've had issues with the 64 bit version of XP .. oh well
Xeno is offline
Old 26-02-2010, 08:54 AM   #9 (permalink)
thank for your help guys
Old 26-02-2010, 10:13 AM   #10 (permalink)
Super Moderator
asingh's Avatar
What issues you had..?
Old 02-03-2010, 06:04 PM   #11 (permalink)
Treatment in progress...
mukherjee's Avatar
that shopkeeper shud have his license revoked
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline
Old 03-03-2010, 06:50 PM   #12 (permalink)
Tux Fan
shaunak's Avatar
Take my advice, and avoid that shop. He clearly does not deserve to live in this century.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 04-03-2010, 07:47 AM   #13 (permalink)
liNux+usER
Nuxer's Avatar
I think the shopkeeper trying to clear out his core2duo based laptops.
Nuxer is offline
ASAP! - New intel PC for asic office use? rohan_kumar011 Hardware Q&A 1 06-02-2010 11:26 AM
Intel 64 bit support BugSlinger PC Components / Configurations 2 22-11-2009 03:40 PM
Intel Extreme Edition (Dual Core) Launched !! mohit CPU / Motherboards 16 20-04-2005 11:18 PM
Gamers Are Spending 700 Dollars a Year on Games, IGN Study Sourabh Gamerz 7 30-03-2005 12:40 PM
- by c4u
