Old 24-02-2010, 04:41 PM   #1 (permalink)
kartikkapo's Avatar
Default Portable HDD
I want buy a 320GB portable HDD. My budget is 4000/- basically i need a hdd which has a long life and some durability.
I would personally like to go for Seagate, but i'm still not sure.
So which one is better one..
--> Iomega
--> Seagate
--> Western Digital
thanks
kartikkapo is offline
Old 24-02-2010, 05:19 PM   #2 (permalink)
Legendary Darknight
latino_ansari's Avatar
Default Re: Portable HDD
i would suggest to go with Seagate... i comes with 5yrs warranty and performs decently....
latino_ansari is offline
Old 24-02-2010, 06:10 PM   #3 (permalink)
live life king like...
hot zubs's Avatar
+1 for seagate
and d design z also pretty gud...
Core i5 2400, Intel DH67BL-B3, 2GB Corsair DDR3, Geforce 8600GT, Seagate 1TB, LG 20x , BenQ E2220 HD, Creative M4500 , CM extreme 600W, CM 690, APC BackUPS -ES650VA
hot zubs is offline
Old 25-02-2010, 09:45 AM   #4 (permalink)
kartikkapo's Avatar
thank u guys for the suggestions..
Is Seagate raptor still available? Or should i buy The FreeAgent GO?
Old 25-02-2010, 12:01 PM   #5 (permalink)
hot zubs's Avatar
there was no seagate raptor in seagate dude, raptor was in Western Digital...
So u hav 2 go with seagate free agent only...
hot zubs is offline
Old 02-03-2010, 06:30 PM   #6 (permalink)
Treatment in progress...
mukherjee's Avatar
seagate freeagent 320GB!
m myself using one for the last 1.5yrs....no trouble at all!
PC: Core i7 2600K||Z68V Pro||Noctua U12P SE2
Vengeance 1600Mhz 8GB||GTX560Ti HAWK
CM Elite 430||1TB+300GB
VX550||G110||G1 mouse||Razer Goliathus
Photography: Nikon D5100||Nikon 55-300 VRII
Canon Powershot SX220HS||Tamrac Velocity 9x
Audio Gear: Brainwavz M4||Meelec A151|| EP630
PX100 II||Fiio E5||AudioTechnica ATH-T500
mukherjee is offline
Old 02-03-2010, 06:35 PM   #7 (permalink)
I also own a Seagate FreeAgent Go 320GB.
I'm totally satisfied and it will cost you around Rs. 3300.
ico is offline
Old 02-03-2010, 06:51 PM   #8 (permalink)
Legendary Darknight
yeah seagate free agent gb 320 is perfect for ur price.... i have been using it for the last 7 months.... no problem at all...
Old 04-03-2010, 03:41 PM   #9 (permalink)
kartikkapo's Avatar
thanks a lot guys... finally got my hand on SEAGATE freeagent GO 320gb.. classic black...
thanks a lot for ur valuable suggestions..
Old 04-03-2010, 05:00 PM   #10 (permalink)
Legendary Darknight
congrats for the new purchase...
Favorite Portable Applications !!! go4saket Software Q&A 24 25-01-2008 05:42 PM
Portable HDD + Casing Config Help knoughtyd PC Components / Configurations 6 14-11-2007 04:10 PM
MOST USEFUL PORTABLE S/W's <Load into Memory stick & roam anywhere!!> Kiran.dks QnA (read only) 16 27-03-2007 09:41 AM
Portable Apps -External HDD or Notepad HDD +USB Port ? din Peripherals 2 22-08-2006 11:05 AM
- by c4u
