Old 22-02-2010, 10:37 PM   #1 (permalink)
Default Compaq Presario over heating and blue screen error
Hi Guys, I use a Compaq Presario C700 model having Intel Pentium Dual Core 1.73 GHz, 2GB Ram, 150GB HD laptop. The problem with the system is there is too much over heating and shows blue screen error at start up or at the middle of working. I have attached the image of the blue screen with this post.
Need a solution, plz help!!!
cool guy.
spider is offline
Old 22-02-2010, 11:52 PM   #2 (permalink)
Default Re: Compaq Presario over heating and blue screen error
jst see the CPU TEMPERATURE in BIOS SETUP.if it exceeds 60 degree celcius ..ur laptops processor fan must be faulty......you shld give it to compac centre
nikhil2304 is offline
Screen Turns Blue....??? speedyguy QnA (read only) 11 07-12-2005 01:16 PM
- by c4u
