Old 22-02-2010, 11:08 AM   #1 (permalink)
Default Query and suggestion for hard disk under Rs. 3000
hi,
my current rig is not giving the performance i expected from it.i sometimes feel it is slow. My friend told me that it is bcoz of the hdd and i should replace it. i have seagate ide 160gb drive. Therefore, i ran this hd tune test and the results were:
Please advise me whether the laggy performance is really due to the hdd. And if so, please advise the best drive (500gb or higher) available for under Rs. 3000. I will be mainly using it for normal use like surfing, watching movies and a little bit of gaming. I will prefer western digital hdd as they have 5 years onsite warranty.
also, how r these drives and which one is the best:
WD 640gb blue
WD 500gb black
My rig:
Phenom II 940 BE 3.0ghz
Biostar 790gx + 128mb
Corsair 2gb 800mhz
nikhilpoddar is offline
Old 22-02-2010, 11:22 AM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: Query and suggestion for hard disk under Rs. 3000
No I really dont think that this problem is due to hard disk. Where are the results of HD Tune, you just wrote "and the results were:".
What's the problem you are actually facing ? Explain in detail. Your config is pretty good.
Blogging at:
Technostarry
saqib_khan is offline
Age Query and seeking ur suggestion usmayur Gamerz 4 30-03-2006 11:05 PM
- by c4u
