20-02-2010, 10:45 PM
LCD
hello friends,
i want a LCD below Rs.8000
Please give ur best suggestion,details and price.
Regards,
Fatalcore.
Q9550+GA-EP45-UD3L+4GB CORSAIR DDR2 800FSB+XFX GTS250 1GB+250GB SATA+CORSAIR VX450+CM V8+ASUS XONER D2+SATURN+LGDVDRW+CREATIVE 5.1 INSPIRE+500GBX6 FREE GO AGENT+RAZER MOUSE+DELL LATITUDE 6400.
21-02-2010, 07:37 PM
Re: [B]LCD[/B]
Some body please help....
21-02-2010, 08:34 PM
Super Moderator
Re: [B]LCD[/B]
Dell 19"...!
21-02-2010, 08:54 PM
Re: LCD
Please specify the model Number and if possible the price...Please
Thanks,
regards,
fatalcore.
22-02-2010, 12:09 AM
Super Moderator
Re: [B]LCD[/B]
Just check on the DELL India website. Raise a query for 19" model. They will send you a mail with the latest quotations with a working day.
22-02-2010, 12:30 AM
I am the night! I am....
Re: LCD
Originally Posted by fatalcore
hello friends,
Regards,
Fatalcore.
Go for samsung 2033 sw plus @ 7.2k & its 20in.
The scr is 1000:1 & dcr is 50000:1.
Personally using it and its better than dell s1909w which i have too.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
22-02-2010, 01:28 AM
I M A *STAR*
Re: [B]LCD[/B]
^^ +1 . Go for Samsung 2033.
22-02-2010, 11:41 PM
Re: [B]LCD[/B]
I didnot like the lower curve of the LCD, Please suggest a straight line design.
23-02-2010, 01:00 AM
I M A *STAR*
Re: [B]LCD[/B]
ok then, you can go for Dell E1909
23-02-2010, 10:18 AM
Re: [B]LCD[/B]
kool lcd, whats the price in kolkata?How is the quality of this lcd?
Please advice,
regards
fatalcore.
23-02-2010, 10:51 AM
Super Moderator
Re: [B]LCD[/B]
Please do this.
23-02-2010, 03:47 PM
Re: [B]LCD[/B]
Go for BenQ G2200 - 7850 / BenQ G2412 - 11100
Picture comparison
http://detail.zol.com.cn/176/175945/pic.shtml
I guess, G2200 and G2410 will be more of the same, except for the difference in features... But a 22" FULLHD for 7850 is a killer deal.
Of course you can get S2209W for 8850 which is also fullHD. But I guess BenQ is worth it
Intel D930&945GNTL| 2x1GB 667 Mhz(Transcend+Kingston)| 500GBSeagate+200 GB WD|Zotac 9600GT Amp!| Zebronics Platinum 400W|Dell SP2208WFP|Logitech z5500| Lite-onDVD-RW+LGDVD-R
24-02-2010, 05:38 PM
Re: [B]LCD[/B]
Today i checked out the
DELL IN1910N 18.5-inch Widescreen Flat Panel Monitor->5850+
ASUS VH192D->5500+
However Dell E1909 was not there,i was looking for Dell Professional 1909W 19-inch Widescreen Flat Panel Monitor which was also not available.Even the price quotion was not available.
Please suggest,
Fatalcore.
25-02-2010, 12:38 PM
I M A *STAR*
Re: [B]LCD[/B]
I would not suggest to go for 18.5" monitor. Have you inquired about BenQ monitors, take a look at them also. Also take a look at G2200, as emmarbee suggested. You don't have much options left now, as you dont want to go for Dell or Samsung.
25-02-2010, 10:09 PM
Re: [B]LCD[/B]
plz suggest a 19'' LCD/LED(HD) With Straight Line design.Please suggest the price range also.
regards,
fatalcore.
***Note: Please dont suggest more than 19''.
26-02-2010, 07:52 AM
Its Best only if its open
Re: [B]LCD[/B]
Here check this out : 22" lcd monitor
26-02-2010, 09:29 AM
Re: [B]LCD[/B]
^ I guess i asked a LCD less than 19'' specifically.Bro these all are either 22-24".
Regards,
Fatalcore
