Old 20-02-2010, 07:51 AM   #1 (permalink)
Revolution's Avatar
Unhappy Strange Problem With My PC !
Please help me!
My PC Restart 3 times in 4 hours.
That happening from last week.
I have installed fresh XP but problem have not solved.
I have full scanned my PC with Avast and Malwarebytes but there was no virus or trojan.
What should I do now ?.....
Revolution is offline
Old 20-02-2010, 08:37 AM   #2 (permalink)
The Sorcerer's Avatar
Default Re: Strange Problem With My PC !
And how are we supposed to guess the hardware components you use in your pc? If you do not know, google and download cpu-z, click on validate and post the link here.
Hardware BBQ
The Sorcerer is offline
Old 20-02-2010, 09:32 AM   #3 (permalink)
Revolution's Avatar
Intel E2180@2.0GHz
Gigabyte G31 Mobo
2GB Transend DDR2 800MHz RAM
250GB Seagate HDD
Old 20-02-2010, 09:33 AM   #4 (permalink)
Originally Posted by Revolution View Post
Please help me!
check your heatsink, if its loose. chances r yes.
Sam is online now
Old 20-02-2010, 09:56 AM   #5 (permalink)
AJJU
azzu's Avatar
^ i think It must be Problem with PSU
coz had the same problem before
and also overheating issue check all the heat sinks are properly installed
I love and Live to Design
azzu is offline
Old 20-02-2010, 02:14 PM   #6 (permalink)
Make Way the LORD is Here
ssk_the_gr8's Avatar
even i think this is most probably a PSU problem... or over heating... open your cabinet .... vaccum clean it if its dirty & check whether everything is connected properly & not lose
(Gen.1:26-27) New Testament
FORUM RULES - Updated
Don't Buy from Sulekha
ThinkDigit Forum Workspace Showoff Contest
ssk_the_gr8 is offline
Old 20-02-2010, 03:22 PM   #7 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
replacing thermal paste and through clean for dust may help something
When someone dies in the grip of a powerful rage... a curse is born.
Kayako Saeki: Croakkkkkkkkkkkkkkkkkkkkk!
max_demon is offline
Old 20-02-2010, 03:55 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Redo all the electrical connections. Remove all dust.
asingh is online now
Old 21-02-2010, 04:21 AM   #9 (permalink)
Revolution's Avatar
Temp. of CPU OK.
I have checked,my case is clean and cool.
May be the PSU.
I have Zebronics 450W SATA Plus PLU.
Old 21-02-2010, 12:39 PM   #10 (permalink)
IM AS MAD AS HELL!!
max_demon's Avatar
ya ya , i think the problem may be insufficient power , i also faced once when i added an extra hard disk or usb drives pc didnt had power and shut down unexpectedly
Old 21-02-2010, 12:45 PM   #11 (permalink)
TheHumanBot's Avatar
it seems you havent solve it yet with all above methods.
check your psu with your frnd system and see if it restarts or not.
Twitter Handle : /TheHumanBot
TheHumanBot is offline
installation problem veb Buying Advice 0 09-02-2010 11:40 PM
problem with amd anthlon x2 4600,geforce 9500gt bhadkow Hardware Q&A 2 08-02-2010 11:28 PM
APC UPS problem prvprv Hardware Q&A 1 28-01-2010 05:08 PM
Strange problem in LAN sainit Networking 2 13-08-2007 11:49 AM
Strange Mobo Problem........ cvvikram CPU / Motherboards 8 17-06-2005 01:36 PM
- by kool
