Old 18-02-2010, 11:15 PM   #1 (permalink)
Default 4gb kingston pen drive showing 1gb after trying to install Chrome OS
Hi Guys, I've a 4 GB Kingston pen drive which I used to install Chrome o/s that I had downloaded from net. Now as I insert it in my laptop it shows 1GB only. the Pen drive is only 4 months old. What could be the reason and can it be brought back to its original condition?
Plz help guys..........
cool guy.
spider is offline
Old 19-02-2010, 12:49 AM   #2 (permalink)
Sarvesh's Avatar
Default Re: 4gb kingston pen drive showing 1gb after trying to install Chrome OS
Just reformat it.
If doesn't work - open My Computer>Manage>Disk Management - Delete partition and repartition.
If doesn't solve - use HP Flash Drive format.
"If you understand, things are just as they are; if you do not understand, things are just as they are."
http://www.sarvesh.co.nr/
http://digitalmusicrecording.blogspot.com/
Sarvesh is offline
Old 22-02-2010, 09:52 PM   #3 (permalink)
Thumbs up Re: 4gb kingston pen drive showing 1gb after trying to install Chrome OS
Thanks Sarvesh....I used HP Flash Drive Format Tool and finally my Flash Drive is ready to rock...thanks dude.........
cool guy.
spider is offline
Old 23-02-2010, 09:20 AM   #4 (permalink)
paroh's Avatar
This happs with me also when my 8 Gb pen drive only showing as 2Gb drive i even try full format but still it is showing 2Gb. and i also tried hp usb utility to format still no use. Then last i try low level format it takes some time to do low format but now its ok it is showing 8Gb
***********For computer related Problem PM me (If want's Doeacc A Level Project PM Me )************
paroh is offline
Old 07-03-2010, 11:23 PM   #5 (permalink)
Sarvesh's Avatar
Yes in some case when normal format does not work - full low format works.
Sarvesh is offline
4GB pen drive!!! chicha Chit-Chat 6 23-07-2007 11:55 AM
USB pen drive problems the_player Hardware Q&A 2 02-01-2007 11:32 AM
how to format HDD using fdisk? zegulas QnA (read only) 10 18-05-2005 12:41 PM
Kingston USB Pen Drive Data Corruption - Please Help!! lubu Peripherals 4 07-05-2005 12:38 PM
Bizzy's Guide to Good Hard Drive Maintenance bizzyboy QnA (read only) 3 29-12-2004 09:50 PM
- by kool
