Old 18-02-2010, 03:31 PM   #1 (permalink)
Default UPS backup calculation
Can anybody help me in finding the backup of a 500VA UPS with 12V, 7 AH battery... and steps for calculating this...
iiamvin is offline
Old 18-02-2010, 04:54 PM   #2 (permalink)
CA50's Avatar
Default Re: UPS backup calculation
What is your system configuration??
This ups should give backup for 10-15 minutes. This mainly depends on the system. Use of LCD increases the backup time in contrast to the use of CRT. New age Graphics card also consumes lots of power and this also decreases the backup time period.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 18-02-2010, 05:35 PM   #3 (permalink)
Democracy is a myth
rhitwick's Avatar
Thumbs up Re: UPS backup calculation
For those who want a simple just-tell-me-the-bottom-line answer for their UPS needs, American Power Conversion (APC) has a nifty UPS selector that yields three product recommendations (all of them APC, of course) listing them as: best price, best value, and best performance. If nothing else it provides one with a rough idea of what VA range you need to be looking for.
Generally speaking, the VA output rating of the UPS should exceed the load by at least 50% to 100%, so how do you calculate your expected load? The link to BC Hydro’s UPS Guide contains a six-step worksheet using hardware wattage to help determine a UPS for your needs. Very briefly, you simply obtain the wattage of all devices to be connected, bearing in mind that printers are energy hogs and should not be operated on battery backup ever, and then compare this to the total wattage listed by the UPS manufacturer. This will get you into the ballpark area of your UPS needs.
However, the UPS VA rating is not the same as power drain, measured in watts, from the hardware. Some literature suggests a conservative factor of Watts × 1.6=VA, while others list VA × 0.85 to 0.7=Watts. There is no way to accurately know without actually measuring the draw of your hardware with an ammeter. So where does that leave the electronically challenged? As mentioned in the JetCafe link, obtaining a UPS whose VA is equal or greater than the total electric load rating of all hardware will err on the side of caution, and be properly conservative.
If interested read full article here: http://www.atpm.com/13.02/ups.shtml
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 22-02-2010, 10:37 PM   #4 (permalink)
My system Specification:
HP compaq Intel Pentium D 3.4 GHz, 15'' TFT, 80GB HDD, 1GB RAM
iiamvin is offline
APC UPS problem prvprv Hardware Q&A 1 28-01-2010 05:08 PM
!!!UPS Modding!!! + >>>Increase Backup time Manyfold<<< I have done it.... Rollercoaster Hardware Q&A 65 11-04-2009 11:00 AM
Back It UP [for Offices] iMav Tutorials 10 09-02-2008 10:41 PM
- by kool
