I'm planning to buy either Athlon X4 635 processor and Phenom X2 555 BE processor for gaming and video editing. Please suggest a motherboard for the same.
I want a motherboard which will be easy for up-gradation in future.
My budget is Rs.5.5k
@ your budget MSI 785GN-E65 @ 5.6k or
Gigabyte GA-MA785GMT-UD2H @ 5.5k
will be the choice for you. Both are good with solid capacitor design, 4 Ram slot etc, 2 PCI and one PCI express X1 slot, 128 MB DDR3 Sideport memory for HD 4200 Graphics.
If you want little performance board over it, go for the ASUS M4A785TD-V EVO @ 6.4k.
the gigabyte 1 don't have sideport. asus m4a78td-v evo is best premium VFM board for AMD. get it if budget permits.
