Originally Posted by GEEKCOMPUTER_GEEK
Hello,
to all of you.
I want to buy CORE i3 based system.My budget is Rs.30000.Actually, I am in a confusion that Should I buy assemled system or go for some branded system like DELL, because, today I got quotation from local vendor that is Rs.31000 for whole system and today I read ad in the newspaper that Dell's core i3 based system is for Rs.32000 inclusive all taxes and delivery charges.Now, I am in a confusion to which system should I buy assembled or branded.Please reply.Thank you for reading my mail.
Regards,
GEEK_COMPUTERGEEK
As ritwick said need to know the exact configuration for both the systems before a decission can be reached....
---------- Post added at 01:36 AM ---------- Previous post was at 01:31 AM ----------
Hello,
to all of you.
Actually, the configurations are almost same just DELL is giving 320 gb hdd and assembled one is giving 500 gb.
Thank You.
GEEK_COMPUTERGEEK
[COLOR="Silver"]
---------- Post added at 01:16 AM ---------- Previous post was at 01:09 AM ----------
That hard to believe, anyway if you plan to upgrade you system by adding suff later get an assembled one, if you would not need to open up the chassie for no reason get a Branded one as you get better warrenty and services, plus sleeker looks, better cabbie with better cable management.
