Hello ppl. I've been absent from technology sceneraio for some time, so ma knowledge is a bit outdated.
I want to buy a new laptop for about 35k.
I:
surf net n download stuff a lot
like to fiddle with 3dsmax n the likes
do a lot of multitasking
play graphic intensive games(but not equal to a hardcore gamer)
so what do you suggest?
You can consider acer 5542 G it has got AMD Turion II M500 2.2Ghz, 3GB Ram, 15.6" HD LED-BACKLIT display, ATI 4570 Dedicated graphics card with a 512MB DDR3 memory, Fingerprinter, WIFI b/g/draft n, 320GB HDD, HDMI. I bought this for 33k 1 month before with linux. Below 35K this is VFM
i would suggest you to go for dell inspiron series as it is coming with latest core i3 and i5 processors and also the configuration is good(including Graphics card)..also go for smaller size like14" as battery backup is good also they are lighter that others.
Check out this laptop. Go to official HP Site and search for dv6t quad. Click on Customise and Buy button next to 999$. Usmein yeh configuration daalo (this is almost the base configuration).
Which is just above 36,000 Rs. India mein woh price pe ek dum yede jaisa laptops milta hai. Yeh bahut hi achha laptop hai and 36k is totally worth it.
(The coupons are for a very limited time. So in case you decide to buy it, then jaldi karna.)
HP Pavilion dv6t Quad Edition customizable Notebook PC
* Genuine Windows 7 Home Premium 64-bit
* Intel(R) Core(TM) i7-720QM Quad Core processor (1.6GHz, 6MB L3 Cache) with Turbo Boost up to 2.8 GHz
* 3GB DDR3 System Memory (2 Dimm)
* 320GB 7200RPM SATA Hard Drive with HP ProtectSmart Hard Drive Protection
* 1GB Nvidia GeForce GT 320M - For i7 Processors
* 15.6" diagonal High Definition LED HP Brightview Widescreen Display (1366x768)
* LightScribe SuperMulti 8X DVD+/-RW with Double Layer Support
* Webcam + Fingerprint Reader
* Intel Wireless-N Card with Bluetooth
* No TV Tuner w/remote control
* HP Color Matching Keyboard
* 6 Cell Lithium Ion Battery (standard)
* Integrated 56K Modem
* Microsoft(R) Works 9.0
* HP Home & Home Office Store in-box envelope
The catch: Available only in the US. So you need to have someone in the US who can buy it for you (and who's coming to India real soon).
