Old 15-02-2010, 01:03 PM   #1 (permalink)
Post BSNL Broadband Question:
Connection: Home 1000 [384 Kbps upto 2Mbps, 5GB Limit]
Questions:
1. Can this be shared between two computers using a router?
(Independently, not the "one is a server, the other a client" way)
2. If not, then what is a workaround?
3. Is this legal and in line with BSNL terms of usage?
Thanks.
RChandan is offline
Old 15-02-2010, 07:49 PM   #2 (permalink)
Default Re: BSNL Broadband Question:
I think it is possible as bsnl modem in our area is a modem+ router which also has the wireless connectivity. Also most of the colleges and offices are using this too. But bsnl has gives notification that password should be set for the wireless connection due to increasing no.of cybercrimes using these unprotected connections.
iamall is offline
Old 16-02-2010, 07:25 AM   #3 (permalink)
1- can be done.
BSNL gives you a ROuter, when you are getting the modem, choose the modem with the 4 ethernet ports, this will allow you to just plug in your computers via ethernet cabels into the Router and let the router do NAT,
2) i dont need to answer that
3) I dont think it is illegel
parimm is offline
Old 16-02-2010, 09:41 AM   #4 (permalink)
Gracias Senor
dreams's Avatar
You can connect upto 4 computers via ethernet and n number of laptops using wireless. But the speed will be shared. I am currently using AirTel using which I connect 2 laptops using wifi and desktop using ethernet. The same logic can be applied for BSNL too.
This is absolutely not illegal.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
BSNL Unlimited (CDMA -144 kbps) Internet for Rs.250 Per Month din Technology News 447 02-11-2009 08:33 PM
Send Free Unlimited International SMS!! [Tested 100%] sushantvirdi Technology News 53 19-07-2009 11:19 PM
any ways to protect bsnl a/c's n pocketting bandwidths?? abyssman Open Source 4 01-12-2007 03:08 PM
BSNL Names '07 Year of Broadband ssk_the_gr8 Random News 13 31-12-2006 08:27 PM
- by kool
