Old 13-02-2010, 04:53 PM   #1 (permalink)
Default Core i3 or core i5 based system
Hello,
to all of you,
Can any one give the CONFIGURATION OF CORE I3 OR CORE I5 BASED SYSTEM? Thank you.
GEEKCOMPUTER_GEEK
GEEKCOMPUTER_GEEK is offline   Reply With Quote
Old 13-02-2010, 04:59 PM   #2 (permalink)
Default Re: Core i3 or core i5 based system
i also have the same ques.... i want a decent core i5 rig(preferably under 30K-35k excluding monitor)....
rahul_007 is offline   Reply With Quote
Old 13-02-2010, 08:23 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Core i3 i530 2.8GHz @ 6k
INTEL H55TC @ 5.6k
4GB DDR3 1333MHz Transcend @ 4.4k
CM Elite 310 @ 1.5k
Gigabyte 460W @ 2.2k
Seagate 500GB @ 2.4k
Logitech Kbd/mouse combo @ 1k
Altec Lansing 2.1 BXR1121 @ 1.2k
LG 22x DVD @ 1.1k
BenQ 22" G2220 FULL HD LCD Monitor @ 8k
You didn't mention whether u need a GPU or not...
@ Rahul_007
INTEL H55TC @ 5.6k
CM Elite 310 @ 1.5k
LG 22x DVD @ 1.1k
And
Sapphire HD5670 512MB GDDR5 @ 5.6k
IMHO, the processor+motherboard should be this as it's faster yet cheaper by 1.6k:-
Athlon II X4 630 2.8GHz @ 5.2k
ECS 785GM-M @ 4.8k
About me:
http://about.me/preetam_nath
comp@ddict is offline   Reply With Quote
Old 13-02-2010, 10:03 PM   #4 (permalink)
can you please suggest me a mobo other than intel as i overclock my pc.
---------- Post added at 10:00 PM ---------- Previous post was at 09:56 PM ----------
thanks man....
---------- Post added at 10:01 PM ---------- Previous post was at 10:00 PM ----------
ok.... thanks....
---------- Post added at 10:03 PM ---------- Previous post was at 10:01 PM ----------
ok.... thanks....
Old 13-02-2010, 11:56 PM   #5 (permalink)
I am the night! I am....
vickybat's Avatar
Hi rahul_007
Buddy if you're planning the pc for gaming then the i3 530 is a good option not because its a dual core but of its onboard pci-express controller that communicates with the gpu directly.
But if you do a lot media transcoding like conversion then the amd athlon x4 is a good option.Sure hyperthreading allows the i3 530 to work simultaneously in 4 threads but 4 physical cores which the amd offers makes a difference and price to performance wise, its a more viable option.
Regarding on the non intel mobo for i3 , try the ASUS P7H55D-M EVO LGA 1156 Intel H55 or look for gigabyte or msi boards of same h55 chipset.
You can also try p55 boards but you'll be unable to use the on-die gpu of i3 530 in case you dont buy a discrete gpu.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline   Reply With Quote
Old 14-02-2010, 02:39 PM   #6 (permalink)
i am just a casual gamer.. should i go for a core i3 based lappy or core i5 based rig??
Old 14-02-2010, 03:23 PM   #7 (permalink)
vickybat's Avatar
Depends on you.Since you say you're a casual gamer then the i3 is best for you.
If portability and mobility is your thing then go with an inspiron laptop with core i3 proccy and ati 4330 graphics.
But a desktop is more future proof and opens a lot upgrading options in the long run sans mobility.
Your call.......
Old 14-02-2010, 08:00 PM   #8 (permalink)
Welbeck fan :D
XTerminator's Avatar
http://www.pcgameshardware.com/aid,7...eview/Reviews/
this should help u dude
XTerminator is offline   Reply With Quote
Old 14-02-2010, 09:36 PM   #9 (permalink)
Should i go for core i3 540 or core i5 650???
Old 01-04-2010, 06:43 PM   #10 (permalink)
latest price for i3 530?
and can you guys suggest a mobo for this CPU which is non-igp, if the chipset is from Nvidia it would be better rather than intel i think. And the price range of Rs 4.5k-5.5k would be sweet..
and also suggest a GPU for about Rs. 4.5k-5.5k from Nvidia..
jyotirmoy_k is offline   Reply With Quote
Old 12-04-2010, 09:50 AM   #11 (permalink)
keen to learn..
Am a rockstar gamer .i wana buy i5 based machine.plz suggest me the best config+ prices with 20" full hd monitor.and also gpu which can play gta4 well with hight settings. My decision so far is nvidia 9800gt.
a2mn2002 is offline   Reply With Quote
Old 04-07-2010, 01:41 AM   #12 (permalink)
Hi, rave reviews about the ASUS P7H55D-M EVO in AnandTech as well. Any idea about the latest price in Kolkata ?
Arvind.exe is offline   Reply With Quote
Old 04-07-2010, 04:44 PM   #13 (permalink)
gEEK001's Avatar
Smile Re: Core i3 or core i5 based system
Dont go for CM Elite 310 coz for 2k u can get NZXT Gamma which can accomodate 6X120mm fans and has all black interiors
Processor:Intel Core i5 750-9.5k
Motherboard:Gigabyte GA-H55M-S2H-5.5k
Graphics Card:MSI GeForce GTS250-5.8k
RAM:Corsair XMS 1333Mhz 4GB DDR3-6k
Hard Drive:WD Caviar Black 500GB-2.5k
Cabinet:NZXT Gamma-2k
SMPS:Gigabyte 460W-2.2k
ODD:LG H55N-1k
Keyboard and Mouse:Logitech Combo-0.5k
TOTAL:35K
This is the best PC u can get in 35k with Core i5
and don't buy any GPU other than GTS250 bcoz it easily outperforms any card under 6k!!!!!
gEEK001 is offline   Reply With Quote
Old 05-07-2010, 09:02 AM   #14 (permalink)
keen to learn..
ODD:LG H55N-1k
TOTAL:35K
Great job bro. i also have the same budget to get the same ring.
Now i will add ati hd 5770 1gb @ 9.2k.
would u plz suggest me the best 22 incher monitor Full HD from the following brands:
1. Dell
2. Acer
3. Samsung
I want to make it a TV also.
Old 05-07-2010, 05:53 PM   #15 (permalink)
gEEK001's Avatar
Talking Re: Core i3 or core i5 based system
1. Dell
2. Acer
3. Samsung
Hi! HERE r the options from 3 brands:
Dell S2209W 21.5" FULL HD @ 8.6k
Samsung 2233SW 22" FULL HD LD Monitor @ 9.2k
BenQ 22" G2220 FULL HD LCD Monitor @ 7.5k(gr8 VMF)
If ur Budget is 12k den go for Dell s2409W 24" Display!!!!
---------- Post added at 05:47 PM ---------- Previous post was at 05:45 PM ----------
@a2mn2002
here r some more suggestions:::
AOC F22 22" FULL HD LCD Monitor @ 8.8k
ViewSonic VX2233wm 21.5" FULL HD LCD Monitor @ 8k
---------- Post added at 05:49 PM ---------- Previous post was at 05:47 PM ----------
If ur budget is low(7-7.5k) den u have one option-BenQ Its a gr88 LCD My friend uses it and if udget is flexible(8-8.5k) den DELL ftw!!
---------- Post added at 05:53 PM ---------- Previous post was at 05:49 PM ----------
latest Price of i3 530 is arnd 5.5k and for mobo go for Gigabyte GA-H55M-S2H for arnd 5.7k and gor GPU increase ur budget a bit and go for MSI GTS250 which can outperform any card in this price range!!!!!!!!!!!!!!
Old 05-07-2010, 07:15 PM   #16 (permalink)
Go for Dell s2409W 24" Display!!!!
I am using this display from 1.5yrs.. you won't regret it!
Work consists of whatever a body is obliged to do, and play consists of whatever a body is not obliged to do.
hsnayvid is offline   Reply With Quote
Old 06-07-2010, 08:50 AM   #17 (permalink)
keen to learn..
@gEEK001 : thnx bro for ur great suggestions. But how to use a HD monitor for a TV?
Should i need to buy a TV tunner ,if yes, which one?
Is there any 22"-23" allrounder avialble (Lcd + inbuilt Tv tuner) as samsung p series does.? is this good one
Old 06-07-2010, 04:57 PM   #18 (permalink)
gEEK001's Avatar
Samsung P series r gud! If ur budget is 13-14k u can go for samsung konect Plus 23" with inbuilt TV tune else buy a TV tuner card for arnd 2k!!!!!!!
Please List Basic C2D / Dual Core Overclocking Tips Choto Cheeta Overclocking 101 18-12-2007 09:31 PM
Recovering from a corrupted regisry which is stopping windows xp to start piyushp_20 Tutorials 2 14-07-2007 01:40 PM
Unleash the Power of Ubuntu 6.06!! JGuru Open Source 72 06-12-2006 10:45 PM
BIOS updates - How to recover sagargv Tutorials 16 22-03-2006 09:35 AM
- by kool
