Old 12-02-2010, 08:16 PM   #1 (permalink)
Default Need help choosing 15-16" LCD Monitors
Hi,
I want to buy a couple of 15-16" LCD Monitors. One is for office use and the other is for home use (including gaming)... Since I have a slightly tight budget (5-5.5k for office and can stretch a bit more for home) and the available choices arent many here in Madurai, the following is the list that I am looking at...
1. LG W1643 model
2. Acer X163WA model
3. Viewsonic VA1601W model
4. Samsung 633NW model
I request people to share their experience (positive and negative) with any of these models to help me choose...
Thanks in advance
Arun
sakumar79 is offline
Old 13-02-2010, 11:18 AM   #2 (permalink)
harryneopotter's Avatar
Default Re: Need help choosing 15-16" LCD Monitors
For office get Benq/Viewsonic 16" models. They are good enough for office usage. And for your home, stretch your budget to 6 k if you can and get Dell IN1910N, 18.5" !
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 13-02-2010, 11:26 AM   #3 (permalink)
I am also getting Benq and Phillips models in another shop... The Benq, LG, Acer and Phillips all are 4.8 or 4.9k, whereas the Samsung model is coming at 5.6k
Arun
Old 13-02-2010, 09:01 PM   #4 (permalink)
4Ghz Here I come !
Demonkiller's Avatar
Arun
Just splurge 1k more and get an Acer 18.5" for 6.5k
e6750 Lapped(3.2Ghz Constant),AC7,P5N-e SLI,XMS2 1066 2x1+G.Skill PK's 2x1Gb,Ultra X2 750W,EVGA 8800GT SC+Galaxy 8800GT SLI
e4300@3.5 http://valid.x86-secret.com/show_oc.php?id=310431
Demonkiller is offline
Old 14-02-2010, 11:54 AM   #5 (permalink)
For the office system, I dont want to splurge. I want to choose between Benq, LG, Acer and Phillips... For the home system, I am willing to go upto 6k, but prefer better performance with lower screen size to lower performance with larger screen size... Of course, better performance with larger screen size will be better, but it should fit the budget... Currently I am using 17" CRT monitor at home and am comfortable even with 1024x768 resolution... At home, it is mostly for slightly old games (like POP TTT and Diablo 2) and not the latest games... Dont watch movies on PC...
Arun
Old 16-02-2010, 08:24 AM   #6 (permalink)
Among LG, Acer, Benq and Philips, which is better in terms of performance and reliability? For office system, I will go for one of these four...
Also, is extra 1k for Samsung worth it? Is its performance and reliability better than the others? If so, I will go for it for the home system...
Arun
Old 16-02-2010, 10:31 AM   #7 (permalink)
I am the night! I am....
vickybat's Avatar
@ sakumar79
Go for a 16 inch benq for office use.
For home use look for dell's s1909 which is a great 18.5 incher and retails around 5.9k with dvi port.
Though that model seems to be phased out and finding it might be an issue.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 16-02-2010, 05:58 PM   #8 (permalink)
Is LG okay? I would prefer it to Acer or Benq as I feel service here will be easier for LG...
Arun
Old 17-02-2010, 06:45 AM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ get what vickybat has suggested to you
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 19-02-2010, 07:06 AM   #10 (permalink)
I got Dell 1910N for home for 6.3k... For office, Benq was out of stock at the store, so I will be getting it most probs next week beginning only...
Arun
Old 20-02-2010, 06:49 AM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ congrats
topgear is offline
Old 20-02-2010, 10:16 AM   #12 (permalink)
Got Benq G610HDA now for 4.55k, but found that specs say 1366x768 as resolution but anything more than 1024x768 60 Hz gives out various warnings... Any ideas?
Arun
Old 21-02-2010, 05:54 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
Unistall your VGA drivers and reinstall them and if there's a driver for the monitor in the CD install it as well. See if you can set it to the native resolution.
topgear is offline
Old 21-02-2010, 11:50 AM   #14 (permalink)
Installed monitor drivers from CD... Tried on three computers, all same result... Anyway it is not a major issue because I dont need more than 1024x768...
Arun
Old 22-02-2010, 06:38 AM   #15 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ If you can live with that fine ......
topgear is offline
My Micro HT Setup Review “Onkyo 6200 HTiB, LG LH70 47 LCD, Panasonic BD60 BRp” sam9s Reviews 14 02-05-2010 05:00 PM
Plasma & LCD TV, what are they ... iMav TVs / Monitors 2 30-04-2007 11:49 PM
LCD Monitors r4gs TVs / Monitors 3 12-12-2006 12:08 PM
Help choosing for Dual Monitors jay4u QnA (read only) 6 06-12-2005 04:35 PM
- by kool
