Old 10-02-2010, 05:08 PM   #1 (permalink)
Default Plz help to store data to avoid loss..
Please tell me how and where I can store my system data so that I can enjoy full peace of mind without any fear of loss?
kelton is offline
Old 16-02-2010, 07:20 AM   #2 (permalink)
Default Re: Plz help to store data to avoid loss..
get two hard drives and RAID-1 http://en.wikipedia.org/wiki/RAID#RAID_1
parimm is offline
Old 16-02-2010, 11:02 AM   #3 (permalink)
Democracy is a myth
rhitwick's Avatar
Smile Re: Plz help to store data to avoid loss..
Buy as many HDDs as u can afford.
Keep 2-3 copies of ur data and prey that all those HDDs don't crash at the same time.
There is nothing full proof, technique for safe date.
For home users, u can think about SSDs (till now I've not heard of SSd crashing).
Then, if u can get a SAN
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is online now
Old 17-02-2010, 07:56 AM   #4 (permalink)
At Hell's Disq
hellgate's Avatar
If u r talking about DCs, better take system state backups & store then in HDD and burn a copy in dvd. Do not use non ad aware backup software as restoring that backup will cause a USN Rollback (in plain simple word ur screwed)
If ur talking bout workgroup desktops, then backup data to another HDD & also burn a copy in a DVD.
hellgate is offline
Old 18-02-2010, 04:51 PM   #5 (permalink)
CA50's Avatar
better make bankups on DVD-RWs. It is cheap and efficient method.
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline
Old 18-02-2010, 10:00 PM   #6 (permalink)
The High 5 Flyer
sam9s's Avatar
I would go with PARIMM method, if you are very particular about your data, get two HDD and connect then using RAID 1.
But remember as its is based on Mirroring if you have 1 TB (2X500 GB) disk you can only use the setup to store 500 GB of data.
RAID 1 mirrors the contents of the disks, making a form of 1:1 ratio realtime backup. The contents of each disk in the array are identical to that of every other disk in the array. A RAID 1 array requires a minimum of two drives. Although RAID 1's writing process copies the data identically to all drives, a RAID 1 mirror would not be suitable as a permanent backup solution for businesses, since RAID architecture by design allows for certain failures to take place (e.g. vandalism or accidental file deletion). However for home or other applications, where vandalism is very unlikely and accidental file deletion is put up with, RAID 1 offers a good backup solution.
Other methods are too time consuming or cumbersome or both
sam9s is offline
Old 26-02-2010, 02:21 PM   #7 (permalink)
Hey friend you can also have another option to store your data offsite that means your data will get stored at another location on a remote server.
Data storage other than storage medias gives you more protection to your data from any kind of threat or virus. It is an automated method.
pearly is offline
Old 17-03-2010, 03:23 PM   #8 (permalink)
Thanks for providing number of ways to store my system data. I think now loss of data never hinders if i use these methods.
kelton is offline
Old 17-03-2010, 03:48 PM   #9 (permalink)
The High 5 Flyer
sam9s's Avatar
Though I appreciate your coming back and acknowledging the efforts of forums members, but I am curious, you started the thread on 10th Feb and cared to check back on 17th March!!!!
sam9s is offline
Old 26-03-2010, 12:19 PM   #10 (permalink)
I think we are free to visit forum any time. Actually I was busy with some work so could not answer the discussion.
kelton is offline
Old 26-03-2010, 05:58 PM   #11 (permalink)
Extreme Poster
actually u should upload all your data to adrive . it offers free online 50GB storage
Cool PC Guy Ken is offline
Old 09-04-2010, 04:17 PM   #12 (permalink)
You can also try unmatched data security and easy restore with FiveBackup software.
pearly is offline
Old 24-04-2010, 06:09 PM   #13 (permalink)
You can use external HDD and pendrives to secure your data and keep them in a safe place for more protection.
fenton is offline
Old 24-04-2010, 06:16 PM   #14 (permalink)
huntluck's Avatar
hahaha......lol You seriously posted this thread or was it for fun
Get an Kingston SSD If you have lower data size....
ASUS M4A78EM/1394 | AMD 720 X3 | ADATA 2GB | IBALL 450WATT | IBALL i612 | TVS GOLD | IBALL 800dpi | WIN XP | SAMSUNG LCDTV 550 32" | HDD 160GB + 320GB
huntluck is offline
Old 10-05-2010, 05:48 PM   #15 (permalink)
It doesnot seem like what you are saying..
I think he is not aware of backup concept...
fenton is offline
Is Global Warming a Hoax? Rahim Fight Club 82 03-05-2011 06:15 AM
Play with Registry Editor kal_21 Tutorials 16 26-12-2007 09:02 PM
Data lost....Help plz h_kunte QnA (read only) 4 25-11-2005 04:33 PM
Data Trimming Hlp me plz Butterfly QnA (read only) 1 06-01-2005 07:42 PM
- by kool
