Old 10-02-2010, 12:07 AM   #1 (permalink)
Default Confused between WD and seagate :(
I wanna buy a 1TB Hdd. as i m running out of my existing storage. Not really needed for backup.
Which one is better of the two ?
Western Digital Caviar Green WD10EARS 1TB 5400 RPM 64MB Cache SATA 3.0Gb/s ----------- Rs.4,450.00/-
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s -----------Rs.4,375.00/-
Prices are similar.
While WD has more Cache memory, Seagate has more RPM.
Which one is better of the two ? in terms of - After sales service/warranty/performance/durability
Thanks
suhas_sm is offline
Old 10-02-2010, 05:20 AM   #2 (permalink)
BE FREE
Default Re: Confused between WD and seagate :(
both are good, seagate has 5 years warranty , no idea of WD, however for external stay away from 1tb sgt ones.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 10-02-2010, 12:31 PM   #3 (permalink)
harryneopotter's Avatar
Seagate internal drives offer 3 yr warranty while WD Provides 5 year ON SITE warranty.
Choice is urs.
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 10-02-2010, 02:00 PM   #4 (permalink)
i think its better to go for the 7200RPM one, 32mb of buffer is sufficient these days i have Seagate 250Gb with 16mb buffer, more than 2yrs old but works fine and is decently fast enough.
23vamsi88 is offline
Old 10-02-2010, 03:18 PM   #5 (permalink)
Going for 7200.12 series.
Since it uses 500Gb size platters compared to other who uses 333Gb platters, it turned out to quite fats according to reviews. WD is good if u want to use it for purely backup purpose and to save some energy
Thanks anyways
suhas_sm is offline
WD or Seagate ????? codename_romeo Hardware Q&A 4 01-09-2009 10:18 AM
Seagate Freeagent or WD My Passport? VD17 Hardware Q&A 5 16-08-2009 09:16 PM
Seagate Barracuda 7200.11 500GB OR WD CaviarŪ 500GB SE16 sam9s Hardware Q&A 6 19-02-2008 10:30 PM
WD or Seagate HDD? narangz QnA (read only) 28 01-02-2008 11:57 PM
- by kool
