Old 09-02-2010, 06:00 PM   #1 (permalink)
Exclamation Questions on Insipiron Zino HD ?
Is there anyone using Insipiron Zino HD ?
Really liked the small factor size of it rather then using HUGE cabinets with fans sounding like helicopter..
Looking for users/review of Insipiron Zino HD sold in INDIA -
http://www1.ap.dell.com/in/en/home/d...=dhs&cs=indhs1
Main Use - Normal surfing, HD Movies by HDMI out to LCD, MS office works,
Price around - Zino HD with 512MB ATI Mobility Radeon HD 4330 = 26500 Rs
Any comments on :
AMD Athlon(TM) 2650e Processor Vs AMD Athlon(TM) X2 3250e Dual-Core Processor ?
Dell IN1910N 18.5" Widescreen Or upgrade to Dell S2209WFP 21.5 " Full HD ?
Normal Or 512MB ATI Mobility Radeon HD 4330 Card ? Will it be able to play HDMI 1080p ?
Config says (Integrated Audio (analog stereo 2.1 on Audio Jack and digital 5.1. capable over) - What is digital 5.1. capable over ?
Give your views on this..
PraKs is offline
Old 09-02-2010, 08:09 PM   #2 (permalink)
I am the night! I am....
vickybat's Avatar
Default Re: Questions on Insipiron Zino HD ?
@ PraKs
Hi buddy
No need to pay 26k for zino.Assemble the htpc for your needs.
At that budget an assembled rig will demolish the zino.
Buying small form factor cabinets, good psu and good quality 120mm fans with slightly low rpm rating will significantly decrease the heat and helicopter like noise levels
Here goes your config..
Athlon II X2 240 2.8GHz @ 2.8k
ECS MCP61M-M3 AM3 @ 2.4k
4GB DDR3 1333mhz Transcend/Kingston @ 4.4k
Zebronics Krish @ 1k
Logitech Multimedia Keyboard/Mouse Combo @ 0.8k
Seagate Barracuda 7200.12 500GB @ 2.4k
LG 22x DVD @ 1.1k
BenQ 22" G2220 FULL HD LCD Monitor @ 8k
Gigabyte 80 Plus Active PFC 460W @ 2.2k
Sapphire HD5670 512MB GDDR5 @ 5.6k
TOTAL = 30.7k
Though it exceeds your budget a bit, you can cut down on ram with a single stick and opt for one later.
For gpu a radeon 5450 will cut down prices by around 3k which is an ideal htpc card.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 10-02-2010, 03:52 PM   #3 (permalink)
Thank you vickybat
All I hate about assembled system is Horrible fan noise it makes, I am yet to find a cabinet & fan which makes minimum noise. I wonder how Dell & HP cabinets are so silent.
Already have an assembled system & fan makes noise similar to helicopter. I am not a gaming person. Would prefer to work on SUPER SILENT system.
What do you say ? Any views on Zino HD ?
PraKs is offline
Old 10-02-2010, 07:03 PM   #4 (permalink)
vickybat's Avatar
Smile Re: Questions on Insipiron Zino HD ?
@ PraKs
Look buddy
The specs & performance of zino hd just doesn't cut it at that price no matter how silent it is.
At 27k you can build a much powerful config and put it in good cabby, with a good psu and large fans.
Look at coolermaster or antec cabinets which are very good.
For psu look at corsair cx 400 or gigabyte 460w.Corsair units are extremely silent and give excellent performance.
Cx 400@ 3k or thereabouts.
Seriously buddy try out the specs which i have provided and put them in the above mentioned cabby and psu and believe me it will blow the zino out of the water.
Zino hd is way too much overpriced for its specs.
Planning your assembled rig with the right components will result in a less noisier and will be cooler(thermally).
vickybat is offline
Old 11-02-2010, 03:42 PM   #5 (permalink)
Thanks buddy. Somehow I will not get that small factor with assembled things right.
I do agree price of Zino is on higher side. but i am NOT gaming person at all so I dont need all those high funda graphics card & special LED Cabinets.
PraKs is offline
Old 11-02-2010, 04:23 PM   #6 (permalink)
BSD init pwns System V
hellknight's Avatar
If you want to get a small factor PC then it is better that you go for Zotac Mag, It has Intel Atom 330 and NVIDIA 9400M onboard.. the only downside is that it doesn't have a DVD writer... but still awesome deal at 17.5k with 160 GB HDD and 2 GB RAM
My blog :- www.openenclave.wordpress.com
hellknight is offline
Old 12-02-2010, 03:23 PM   #7 (permalink)
@hellknight
Dont you think AMD Athlon(TM) X2 3250e Dual-Core Processor is better then Intel Atom 330 ?
Never heard of Zotac Mag Atleast I can trust Dell on service part.
what do u say ?
PraKs is offline
Old 13-02-2010, 03:33 PM   #8 (permalink)
hellknight's Avatar
^Actually I never worked on AMD Athlon X2 3250e... so I can't say anything about it.. Zotac Mag is a high-quality product by Zotac which has exclusive deal with NVIDIA for Graphics cards... it has only one drawback IMO, that is the it lacks a DVD drive..
Here is the product page
It costs Rs 17.5k in India currently.
Old 16-02-2010, 04:06 PM   #9 (permalink)
Here is the review of Zino on Anandtech.
Performance shows its better then Intel Atom processor
http://www.anandtech.com/cpuchipsets...oc.aspx?i=3703
PraKs is offline
Old 18-02-2010, 03:52 PM   #10 (permalink)
Anyone on this forum planning to take Insipiron Zino HD ?
PraKs is offline
Old 23-02-2010, 04:47 PM   #11 (permalink)
Any answers ?
PraKs is offline
Old 02-03-2010, 04:36 PM   #12 (permalink)
Has Digit done review of Zino HD or Zotac Mag in Recent issues ?
PraKs is offline
Old 10-03-2010, 02:56 PM   #13 (permalink)
Is there anyone on forum who might be interested in this desktop & willing to discuss ?
PraKs is offline
Old 11-03-2010, 03:24 PM   #14 (permalink)
Point Blanc
Praks, have you ever bought a branded (dell or HP) desktop or laptop.
There is nothing big about them being silent and all, with time anything and everything makes noise. If your CPU cooler is fixed properly with thermal paste put proerly , then there wont be any noise(which comes always from CPU fan) or you can also remove the fan. I am actually facing this problem. I have got compaq desktop which is more than 4 years old.
Now, I am sure that these products are not coming with cooler fans so they wont make noise. And that is what I said earlier remove fan from your CPU cooler and buy some proccy which produces lesser heat. intel atom or amd proccy in zion HD are certainly the starting of those, even intel C2D produce lesser heat.
Same will go for gpu, buy something which produces less heat. likes of HD5450
For reducing space buy some slim line cabinets, from Zebronics or someother good brand(i-ball for me is not one of them, stay away from it IMO).
And foremost spend properly in cooling products for your system. You sound mostly like me. I will also prefer Zion or any intel atom system with some decent gpu for myself, I am not into any heavy stuffs like crazy gaming. Except, theses system wont be much good for multi-tasking a common scenario when we start opening multiple applications.
acewin is offline
Old 11-03-2010, 05:12 PM   #15 (permalink)
Thanks acewin
Do you plan to take Zino HD ? I have seen the Demo, Its small & cute as well plays most HD videos. Has HDMI.. Main plan is to use for netsurfing, download rig & plug to LCD to watch movies. Dont want to invest in WD HD media players.
Main reason is - Leave those big cabinets & hisssing fans like helicopters.
PraKs is offline
Old 11-03-2010, 06:00 PM   #16 (permalink)
Point Blanc
no I am not, not going to invest in a new rig
yep it is nice idea, as I said atom can survive without cooling, but not C2D or dual core proccy. And I was suggested if you think of assembling then get a good heatsink and remove its fan it will become same.
I would like to see how Atom based system or zion would perform in real-time multi tasking, the only reason I would keep away from. But for one thing for sure if you do not hastly start multi tasking use Windows XP they will perform very well.
One good thing about this is you are getting an LCD display and the space it will take is very less.
but if you think of assembling a rig on that line it will certainly cost less. and you will get little better gfx performance from HD5450
acewin is offline
Old 14-03-2010, 03:05 PM   #17 (permalink)
Thanks for input.
I am still waiting to see performance of AMD 3250. I have seen demo of AMD 2650 & inbuilt graphics card.
I am planning to take AMD 3250 & ATI external 4330 graphics card.
Are you aware of anyone who owns Zotac MAG ? Just want to have their word & compare with Zino
PraKs is offline
win 7 shell questions... bhadkow Software Q&A 0 09-02-2010 05:11 PM
All questions about Gnome Theming Here MetalheadGautham Open Source 38 29-12-2007 02:04 PM
Questions...lots of questions... Arachnid Open Source 16 15-06-2005 12:05 PM
Top 20 XP Questions & Remedies rajat22 Software Q&A 9 09-06-2005 01:26 PM
Some questions regarding laptops k_mridul Laptops and Netbooks 4 17-04-2005 04:18 AM
- by kool
