Old 08-02-2010, 11:42 AM   #1 (permalink)
Default Need a gaming RIG in 55k
I Wanted to buy a gaming rig @ 50k.
Actually my budget is around 62-63k, but i have reserverd 10-13k for PRINTER, TV TUNER CARD & WiFI router.
i Have zeroed down on the following config, pls. give me suggestions.
Core i5 - 750/Core i7 - 920 {whichever fits in the budget}
Any MotherBoard {dont have enough knowledge on this}
ATI HD 5750 1GB.
SAMSUNG 2233SW
WDC 1.5/1TB HDD {whichever fits in the budget}
Any Cabinet {dont have enough knowledge on this}
4GB DDR3 GSKILL/CORSAIR/KINGSTON {whichever is good & gives gr8 peromance}
So this is the config for a rig i have zeroed upon with some options.
So pls. suggest me a good system based on this config.
& if possible, pls. suggest PRINTER, TV TUNER CARD & WiFI router.
cool.vicky is offline
Old 09-02-2010, 03:44 PM   #2 (permalink)
laborare est orare
Cilus's Avatar
Default Re: Need a gaming RIG in 55k
1st of all you don't need that much of money for Printer, TV tuner card and Wireless Router. 8k will be sufficient for it.
And the components you are selected are not balanced at all. HD 5750 is not a performance card. Gor for the AMD Phenom II based rig. They will be cheaper and more can be invested on Gfx card. Performance will be almost same for both.
Here goes the AMD based suggestion for you.
CPU: AMD Phenom II 955 BE @ 7.7k
MOBO:
MSI 785GN-E65 @ 5.6k
RAM: Corsair 4GB DDR3 1600MHz C9 Titanium @ 5.8k
HDD: SeaGate 1 TB HDD @ 3.9k
PSU: GlacialPower 650W AA @ 4.6k
Cabinet:
Zebronics Antibiotic @ 2.5k
Monitor:
BenQ 22" G2220 FULL HD LCD Monitor @ 8k
Gfx Card: MSI HD5850 OC 1GB GDDR5 @ 16.5k
Keyboard/Mouse/DVD Writer: 2k
TV Tuner: Avermedia Super 007 @ 1.6k
Router:
D link Wireless router @ 1.9k
MFD (printer/Scanner combo): 5k (very good)
Total is around 65.1k including ur TV Tuner, Wireless Router and printer
Cilus is offline
Old 09-02-2010, 07:50 PM   #3 (permalink)
I am the night! I am....
vickybat's Avatar
Smile Re: Need a gaming RIG in 55k
@ cool.vicky
Hi buddy
For your budget stick with core i5 cpu especially the i5 750.
Its a beast and more future proof than 9 series amd cpu's.
Fit that cpu with a msi or gigabyte p55 board and overclock it and see it demolish all benchmarks.Though the cost will be more around 4k compared to the amd rig but its worth it.
The power draw of i5 is even lesser than amd 955 or 965be cpu's so less electricity bills in the long run and it even performs faster.
As for the gfx card is concerned go for VTX3D HD5850 1GB GDDR5 @ 15.8k.
Seriously no point in buying 955 or 965 cpu's skipping the i5 especially at a budget greater than 60k.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 09-02-2010, 09:44 PM   #4 (permalink)
The High 5 Flyer
sam9s's Avatar
MOBO:
Cabinet:
Monitor:
Router:
Most of the recomendation looks good, except the godawful Zebronics cabbie, I know people might say I got to to save money, but trust me when you are spending 50K+ for a Gaming Machine you might as well spend couple of Ks to get a decent Cabbie. I would suggest Coolermaster 690 atleast. Believe me it DOES make a difference, when all you components run cool and noiseless.(My personal Experience)
Also I would suggest Samsung anytime over BENQ monitors. (My personal experience again)
Lastly for no particular reason I would personally suggest Core i5-750 Over Pheneom.
Regards
Sammy
sam9s is offline
Old 09-02-2010, 10:46 PM   #5 (permalink)
Super Moderator
asingh's Avatar
Ya..get a good cabinet for 50K worth of stuff. Please.
asingh is online now
Old 12-02-2010, 02:00 PM   #6 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
MOBO:
Cabinet:
Monitor:
Router:
Excellent Config, go for this only change these:-
VTX3D HD5850 @ 15.8k
ECS 785GM-M @ 4.8k
CM Centurion 690 @ 4.4k
Transcend 2*2=4GB DDR3 1333MHz C9 @ 4.4k
About me:
http://about.me/preetam_nath
comp@ddict is offline
Need Help in building my new Gaming Rig Sid_gamer Hardware Q&A 84 18-03-2010 05:08 PM
Need Graphics card suggestion for this gaming rig...Help plz fast.... :) vampiredevil Graphic cards 13 14-02-2010 01:54 PM
need a gaming rig under 14k suspect07 Hardware Q&A 1 10-02-2010 05:02 PM
need a gaming rig under 14k suspect07 Hardware Q&A 2 06-02-2010 05:21 PM
Gaming in India—entering the next level Simple_Graduate Gamerz 3 09-04-2007 03:46 PM
- by kool
