Old 07-02-2010, 12:36 PM   #1 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
Default Need Help in building my new Gaming Rig
I want to buy a PC mainly for gaming purposes and my budget is Rs.75,000 ;
I made the following config for it:
Intel Core i7- 920,
MSI X58 Pro motherboard,
6 Gb Kingston Hyper-X DDR3 Trichannel Kit,
Zotac Ge-Force GTX 260 AMP 2 GPU,
Seagate 7200.12 1 Tb HDD,
Cooler Master Silent Pro M600 PSU,
AOC-2236vW Monitor,
LG DVD Writer,
Creative Inspire- A500 Speakers,
Logitech MX-518 Mouse.
Do I need to make any changes in this config ? if yes then can anyone please suggest an alternative ?
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now
Old 07-02-2010, 12:43 PM   #2 (permalink)
Super Moderator
asingh's Avatar
Default Re: Need Help in building my new Gaming Rig
Change the following:
1. GPU : Get a HD5850 or 5870.
2. PSU : Get a Corsair 550W.
3. Monitor : Get a Samsung or DELL of same size. You might manage a 24" too.
---------- Post added at 12:43 PM ---------- Previous post was at 12:39 PM ----------
I had suggested this, but it is without monitor. You can of course change things.
Nehalem Core i7 920 : 14145
Corsair CMPSU-550VX : 5565
PowerColor HD5850 1GB DDR5 : 16144
Corsair TR3X6G - 1333C9 6GB Kit : 8405
Coolermaster HAF 932 : 8992
Gigabyte GA-EX58UD3R : 11275
1TB HDD : ~ 4500
asingh is online now
Old 07-02-2010, 01:06 PM   #3 (permalink)
Sid_gamer's Avatar
Thanks..
Can you please tell me whether Kingston HyperX RAM 6Gb Kit (2Gb x 3 modules) of 1600 MHz will work properly on MSI-X58 Pro Motherboard with Intel Core-i7 920 on it ??
Waiting for an urgent reply...
---------- Post added at 12:47 PM ---------- Previous post was at 12:46 PM ----------
I plan to go SLI for this system in future so will 600 watts be enough ??
---------- Post added at 01:03 PM ---------- Previous post was at 12:47 PM ----------
Is a high end 2.1 channel speaker system better than an entry level 5.1 channel system????
---------- Post added at 01:06 PM ---------- Previous post was at 01:03 PM ----------
Old 07-02-2010, 02:27 PM   #4 (permalink)
Super Moderator
asingh's Avatar
Yes it will. See below.
For SLI keep 750W. I did Xfire on 650W, but it is pushing it tight. You can if you want to. 2.1 is 2.1 channels. 5.1 will give you more satellites. Depends what you want.
Old 07-02-2010, 09:33 PM   #5 (permalink)
Sid_gamer's Avatar
Thanks...But 1600 MHz has a * on it which says When overclocked....Can it work without OC'ing..??
Old 07-02-2010, 09:45 PM   #6 (permalink)
Super Moderator
asingh's Avatar
It cannot. You will need to change RAM timings and adjust the respective voltage. Also DRAM:FSB ratios would need to be modified. Pure OC. So get an OC board.
Old 07-02-2010, 10:12 PM   #7 (permalink)
Sid_gamer's Avatar
What if I go for Gigabyte GA-EX58-UD4P, will it be better than MSI X58 Pro..Please Suggest as I am going to take the whole system tomorrow afternoon..(I Read lots of reviews of both but i m still confused)....
Old 07-02-2010, 10:26 PM   #8 (permalink)
Super Moderator
asingh's Avatar
Get the Gigabyte GA-EX58-UD4P. Layout is better. So how the mezzanine PCI.Ex16 is so close to the RAM slots on the MSI X58 Pro. Feature wise both are same. Also the board cooling looks better on the Gigabyte GA-EX58-UD4P. Though how much is the price differential.
Old 07-02-2010, 10:33 PM   #9 (permalink)
Sid_gamer's Avatar
And i guess the Gigabyte GA-EX58-UD4P supports RAM Modules of upto 2000 Mhz...But does it also need OC'ing ??
Old 07-02-2010, 10:36 PM   #10 (permalink)
Super Moderator
asingh's Avatar
Support for DDR3 2100+/1333/1066/800 MHz memory modules.
You would need to make changes which equals OC.
Old 08-02-2010, 10:41 AM   #11 (permalink)
Sid_gamer's Avatar
Please suggest me a good RAM for MSI X58 PRO....It should work without OC'ing...My budget for the RAM is 9500 INR...
---------- Post added at 10:41 AM ---------- Previous post was at 10:37 AM ----------
If Anyone else has any suggestions for my Rig then they're welcome...
Old 08-02-2010, 10:58 AM   #12 (permalink)
Super Moderator
asingh's Avatar
The board you are getting, is meant to do that. Make system changes, so the RAM is optimized. Whats eating you..?
Old 08-02-2010, 11:09 AM   #13 (permalink)
Sid_gamer's Avatar
Ok so u mean to say that if i make some system changes in the BIOS then the RAM will work ....Will it be easy to do that??.....(Sorry for asking so much about this but I am a novice in OC'ing)...
Old 08-02-2010, 11:28 AM   #14 (permalink)
Super Moderator
asingh's Avatar
Yes it is quite easy. No issues. When you OC the processor, that is when things get complex. For your RAM to run at 2000Mhz or what ever it is rated..
1. Go to the BIOS.
2. Change the FSB : DRAM ratio so it matches EPP.
3. Change the timings. (listed on the RAM)
4. Change the voltage. (listed on the RAM)
5. Commit changes, restart.
Old 08-02-2010, 05:13 PM   #15 (permalink)
Sid_gamer's Avatar
I think i should go for water cooling in this rig....What do u suggest????
Is corsair H50 Hydro good, or should i install a totally custom water cooler??
Old 08-02-2010, 06:28 PM   #16 (permalink)
Super Moderator
asingh's Avatar
Doubt you will need water cooling. Just get a OEM HSF.
Old 08-02-2010, 06:40 PM   #17 (permalink)
why u pushing so much into proccy OC & cooling land, when u should mainly concerned about GFX card setup if u building an gaming rip rather than an Benchmark Rig. Spend more where its necessary. Get a Dell/Benq/Samsung 24" + HD5870. & then game on it. asigh gt 2 X HD4890 in CFX so 1 single HD5870 should perform equally as both setup cost almost same. U good to go with a core i5 + H55.
Sam is online now
Old 08-02-2010, 07:38 PM   #18 (permalink)
Super Moderator
asingh's Avatar
He is going for X58/i7/HD5870. It will rip the pants off my system any day.
Old 08-02-2010, 08:16 PM   #19 (permalink)
^^still u created a fantastic gaming rig. his main advantage wil be i7. though 6Gb ram wil have its own side effect.
Sam is online now
Old 09-02-2010, 09:50 AM   #20 (permalink)
Super Moderator
asingh's Avatar
Meaning bad or good, the 6 GB of RAM.
Old 09-02-2010, 10:36 AM   #21 (permalink)
Sid_gamer's Avatar
I hope the side effect will be good...My fingers are crossed....
Old 09-02-2010, 10:52 AM   #22 (permalink)
Super Moderator
asingh's Avatar
It will..has too. The X58 is meant for 3 sticks -- tri-channel. Will OC nice too. No instability, at all.
Old 09-02-2010, 12:11 PM   #23 (permalink)
Sid_gamer's Avatar
Is Corsair TR3X6G1333C9 (XMS3) a high performance and overclockable RAM ???
Old 09-02-2010, 12:47 PM   #24 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
yes, it is a really good OCing RAM module, i hv Corsair TR3X3G 1333Mhz RAM the only difference b/w ur and mine is tat i hv 3X1GB and u will be having 6X1GB sticks..
and yes, the FVGA's X58 mobo is a beast mobo wen it comes to OCing and its way too stable.., MSi is good too but Evga is above it by far..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is online now
Old 09-02-2010, 12:57 PM   #25 (permalink)
Super Moderator
asingh's Avatar
Instead of him getting 6 sticks of 1 GB each, would it not be better to get 3 sticks of 2 GB each. And keep 3 slots free for future upgrades, and have 6 GB.
Just checked:
Corsair TR3X6G1333C9 is 3x2.
@Sid:
Get one concept clear. RAM can be OC'ed but it is difficult. In the sense, to get it above the specified EPP rating. Yes, to get it @ 1333MHz @ latencies of 9-9-9-24, you will OC, but not literally. You are running it at the settings it has been tested and verified at. Now if you get it > 1333Mhz, that is PURE OC for the RAM. Hope am making sense. This Corsair TR3X6G1333C9 is good. Corsair seriously kicks a**, be it PSUs or RAM.
Old 09-02-2010, 01:01 PM   #26 (permalink)
thanx for the correction..
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 09-02-2010, 01:25 PM   #27 (permalink)
Super Moderator
asingh's Avatar
By the way, how about some benchmarks on that beast of yours. RE5, Warhead tool..?
Old 09-02-2010, 02:15 PM   #28 (permalink)
Sid_gamer's Avatar
Thanks alot guys... I am going out to buy my rig now....Will post replies after buying it...!!!Thanks again...
Old 09-02-2010, 04:42 PM   #29 (permalink)
yah, side effect wil be good only. 6Gb Ram is lot, well for most
Sam is online now
Old 10-02-2010, 04:04 PM   #30 (permalink)
@ asigh, just read in Tom's Hardware, 2 X HD 4890 in Xfire performs better than a single HD5870. the gap only increases once u OC the cards.
Sam is online now
Hardware price list/spec sheet comp@ddict PC Components / Configurations 5532 Yesterday 10:13 PM
need a gaming rig under 14k suspect07 Hardware Q&A 1 10-02-2010 05:02 PM
Please help in building a new rig: Urgent falling Hardware Q&A 36 07-02-2010 02:25 PM
need a gaming rig under 14k suspect07 Hardware Q&A 2 06-02-2010 05:21 PM
Gaming in India—entering the next level Simple_Graduate Gamerz 3 09-04-2007 03:46 PM
- by kool
