Old 02-02-2010, 07:01 PM   #1 (permalink)
Cool Using One CPU as 4 individual PCs ?
I am in a situation where I need 4-8 PCs and all will require only moderate office processing ie. word , excel etc. may be little internet too.
And if you have new i5 or even core2duo for such needs, it will be overkill, so what I am thinking, similar to VPS which lets one powerful server to act as serveral small server, is there any option which let me to do same on desktop environment. eg. VMware let you run multiple OS but it doesn't let you to run all OS on separate monitor with separate keyboard and mouse.
What I am thinking to have 1 powerful machines with 8 GB or more RAM running 4 Desktops ie. each has their own Monitor, keyboard and mouse but single CPU .
Is there any such solution available in market, it can be achived via Software easily though if there is any turnkey sort of solution then kindly show me the ray !
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
Old 02-02-2010, 10:44 PM   #2 (permalink)
Default Re: Using One CPU as 4 individual PCs ?
yep recently i went to a technical fair... and saw a device (i was astonished at first), it connects to the lan port via pci cards or switches and you can connect various monitors, mouse & keyboards at once... its cost was Rs 4000/pc...
rahul941400 is offline
Old 02-02-2010, 11:44 PM   #3 (permalink)
hmm..
Well in linux I have heard something similar ie. such virtualilzation over LAN, however unable to find exactly what I need.
Anyways, what was the name of device ?
Btw, 4000 per PC doesn't look cost effective, anyways, I will try to find it though !
Any other solution ?
~Ricky
Ricky is offline
Old 03-02-2010, 07:35 AM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
http://www.virtualbox.org/ and http://www.vmware.com
kalpik is online now
Old 04-02-2010, 02:11 AM   #5 (permalink)
After looking at your reply I immediately checked your post count and it confirmed that you are a quantity poster who has very little to do with quality !
You just posted, did you read my post clearly ? See the post of rahul941400 , he actually replied my post by reading it.
Kalpik
In pursuit of BIGGER POST COUNT !
~Ricky
Ricky is offline
Old 04-02-2010, 08:43 PM   #6 (permalink)
You can search for Thin Clients... There are 2 companies I am aware of called Enjay and Panache Infotech which offer these...
http://www.enjayworld.com/
http://panache.co.in/index.php
Arun
sakumar79 is offline
Old 13-02-2010, 05:17 AM   #7 (permalink)
Thin client is something different though !
Anyone experience of using LG network MOnitor ?
~Ricky
Ricky is offline
Old 13-02-2010, 08:35 AM   #8 (permalink)
Are there any software licensing issues when we use these technologies? If we use the LG network monitor to create four PCs from one CPU, will one license for the software (apps) suffice? As per website for windows we need a server license and some client licenses... How much do these cost?
EDIT: Also, what are the cost of these devices?
Arun
Old 14-02-2010, 01:10 PM   #9 (permalink)
vikasg03's Avatar
use N-computing................. Small 4*4 inch box cost around 8-10K.We r using for last 1 yr..
Vikas
vikasg03 is offline
Old 17-02-2010, 07:42 AM   #10 (permalink)
At Hell's Disq
hellgate's Avatar
u can do 1 thing:
run all the OS that u want thru VMWare/Hyper-V (if u wanna go the Win server 2008 R2 way).
Then u can get some 2nd hand PIII/PIV machines for real cheap & do RDP to the VMs & do ur work.
hellgate is offline
Old 17-02-2010, 09:19 AM   #11 (permalink)
Bond, Desi Bond!
desiibond's Avatar
Kalpik
Mind yourself buddy. Kalpik is one of the elite digitians that we respect and if his reply doesn't answer your question, you rather reply in a polite manner.
coming to the topic, LG network monitor will be an ideal way to go.
http://panache.co.in/store/index.php...05b79857b9cc46
But there are other companies that can provide similar setup for much lower price. You may need to dig this forum. We (digitians) had a long discussion about putting up a similar setup.
desiibond is offline
Old 17-02-2010, 01:39 PM   #12 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Kalpik
LOL..many members here are in a spree to get the old members back and you are trying somewhat different.
If you are really a qualitative poster, please.. Forum needs you. Help the forum... in that process some or other will tell 'you are a spammer, you are posting for bumping your post count.' And then you will understand what it will be like. No offense to you buddy.It is just our instincts.
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is online now
Old 23-03-2010, 01:07 AM   #13 (permalink)
Hmm...
(IGNORING all OFFTOPIC REPLIES)
Ummm...
(Now talking about the topic)..
Ncomputing was the obvious choice but for this you need a card which cost big.. namely X550 from ncomputing .. LG also uses same card .. basically LG Network Monitor are something with Ncomputing device inbuilt and using Ncomputing X550 card in server itself.
But cost differences are not big.. per terminal I will save 2-3 thousand and that is not signficant unless I have really big setup.. say 100 or more terminals.
~Ricky
Ricky is offline
Old 23-03-2010, 04:28 PM   #14 (permalink)
cute.bandar's Avatar
Good question, i was looking for someting similar .
Here is another thinclient solution @ Rs. 3500/station.
I remember coming across a software solution recently . But I can't find it now. will google for it. btw i am curious even if there is a software solution , how will all the monitors/keyboards/monitors could be connected to a single cabinet ?split cables or something ?
cute.bandar is offline
Old 23-03-2010, 04:41 PM   #15 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Kalpik
Uncalled for and totally unnecessary, but since you want to get all uptight about that way lets back up a moment. Did you even take the time to take a look at those links? Vmware provides a product line which caters exactly to what you need. Unfortunately you were so busy giving him a hard time that you hardly even knew it.
And no its not. Whenever a system depends on another host to perform its functions then basically its a thin client. In this case those 4 client computers regardless of what method you use to achieve the above mentioned in your post are called thin clients.
What you may also gain in cost savings you may lose in Maintenance as well. Lets say that for whatever reason your main system goes down you lose productivity not only on that machine but every other client connected to it. Not to mention the hassle of setting up devices like printers on clients like these. I still haven't gotten over the nightmare of helping a friend do something similar with Citrix.
FilledVoid is offline
Old 23-03-2010, 05:06 PM   #16 (permalink)
you reignited my interest in this topic , and i found something good!
review of 3 software programs that look perfect for the job. They are ofcourse different from thinclients and cheaper as well ( i think)
the term you are looking for here is multiseat windows.
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
Please List Basic C2D / Dual Core Overclocking Tips Choto Cheeta Overclocking 101 18-12-2007 09:31 PM
Nokia Processors - Hope its useful! solomon_paulraj Mobiles and Tablets 4 31-10-2007 02:57 PM
- by kool
