Old 02-02-2010, 05:08 PM   #1 (permalink)
Default what to do with 2 isp connections on one pc??
hi
i had an internet connection previously which is 256 kbps. now i got a new 1mbps connection for downloads. now my 256 line is left unused with 6 months subscription remaining. wht can be done with it? can i use an extra lan card on pci to use that? is it possible to use both the connections to get an additive speed.
raja2281 is offline
Old 02-02-2010, 07:05 PM   #2 (permalink)
p_dude's Avatar
Default Re: what to do with 2 isp connections on one pc??
Originally Posted by raja2281 View Post
hi
i was using two connection about a year back i used to bridge both the adapters while downloading(only torrents) and it worked well
but i cant guarantee that you can do the same with browsing or html downloads.
p_dude is offline
Boost ur net speed :) almighty Tutorials 73 31-03-2010 01:31 PM
Faster torrent speeds(Router-Client Config.) yrana2002 Tutorials 53 11-09-2007 10:33 PM
Increase bandwidth speeds( finally smthin that works) blademast3r Tutorials 12 16-03-2007 09:08 PM
Using Two Internet Connections at The same time siddharth> Software Q&A 6 17-07-2006 08:22 PM
Make ur Internet n Bandwidth Rapid - Rapid Speeds 100% works Quiz_Master Tutorials 4 12-02-2006 10:50 PM
- by kool
