Old 31-01-2010, 05:33 PM   #1 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Looking for a good Wireless Keyboard
I'm looking for a good Wireless Keyboard within the budget of Rs. 2500. I have come across with Logitech K340 and it looks and sounds good. Should I go with it? Any suggestions are welcome.
debsuvra is offline
Old 02-02-2010, 10:29 AM   #2 (permalink)
BLUE IS THE COLOUR
ajai5777's Avatar
Default Re: Looking for a good Wireless Keyboard
Are the battery models any good..?
My budget is 2k. I found many in that range in microsoft.Are they gud..? Do we need to change batteries every month or so.? Butthey claim 6months batter life.
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
ajai5777 is offline
Old 02-02-2010, 11:16 AM   #3 (permalink)
Gracias Senor
dreams's Avatar
I am using the MS one. Problem is, KB doesnt have any LED on it, for caps and num lock. Even if my computer is turned off, mouse stays on. This decreases its battery life a lot. I do not know, whether it is a problem or designed it tht way.
Logitech suld be good.
iPT 2G(S) - 8GB - JBn
iPhone 3GS 16GB - JBn
MAC OSx86 on P4 2.4Ghz
HTC Touch - Elfin - P3452 - WM 6.5
- Dont Dre@m... Juz Chase it -
dreams is offline
Old 03-02-2010, 12:43 AM   #4 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Talking Re: Looking for a good Wireless Keyboard
Anyway, I finally went with the Logitech Wireless Keyboard K340. It'll be shipped within a few days. Hope it'll serve my needs.
debsuvra is offline
Old 08-02-2010, 06:54 PM   #5 (permalink)
How good is keyboard-mouse Logitech MK250? I'm planning to buy that one, primarily for gaming purpose.
akkies_2000 is offline
Basic guide for the right power supply The Sorcerer Power supply / Cabinets / Mods 717 25-04-2012 03:09 AM
Suggest a good earphone Ray Hardware Q&A 13 21-01-2010 11:07 PM
Suggest me a good wireless kb+mouse hailgautam Hardware Q&A 1 08-09-2007 07:29 AM
which anti virus do you all recommand me? thegame_rulez Software Q&A 55 01-04-2005 05:14 AM
- by kool
