Old 30-01-2010, 11:28 AM   #1 (permalink)
Exclamation blue screen in my comp plz need help ty
guys i have a problem in my comp i get a blue screen of death saying
like tis plz see tis img i took wit my camera
and i hav many times reinstalled xp and many times tightened my cables
yeah ta problem gets solved when i tight ta cables near the hard disk.
and i even brought a new hard disk tis prob still continues
my config is
win xp sp 2 , 3 GB ram, Pentium 4 3 ghz,
nvidia 8500 gt 512 mb ,
sir can you plzz solve tis problem
and thank you in advance
gotetiavi is offline
Old 30-01-2010, 07:38 PM   #2 (permalink)
ancientrites's Avatar
Default Re: blue screen in my comp plz need help ty
this happened with me.So i bought a new cables harder ones from ebay.in.But the problem still continued.i started thinking about memory leakage,installed chily memory optimizer.Since then no prob.there are better ram optimizer,just google up.
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
ancientrites is offline
Blue screen of death maverik99 Software Q&A 8 07-10-2007 01:20 PM
Fatal Blue Screen In Xp ayushman9 Software Q&A 14 09-09-2007 08:42 PM
urgent help!!! blue screen restarts !!! blademast3r QnA (read only) 10 25-06-2007 09:01 PM
Blue Screen of Death ssk_the_gr8 Software Q&A 10 24-03-2007 02:59 PM
Windows XP Boot Screen ... Plz help talrejaharish Software Q&A 11 08-10-2004 05:12 PM
- by kool
