Old 27-01-2010, 01:18 PM   #1 (permalink)
Default Assembling a new PC for 80k, Need hardware suggestions!
I'm assembling a new PC for gfx designing and gaming.
Budget is 80k.
I'm looking for Core i7 rig with HD5850 gfx card.
will be buying the rig from mumbai.
Hardware Component:
Monitor LCD/LED: 24'in Dell/Benq
Processor: Core i7 920 D0
Motherboard: Gigabyte (X58A-UD5/UD7) or Any other Recommendations
Ram: 6GB DDR 3 1600/1333 or Any Recommendations
GFX Card: HD 5850 or Any other Recommendations
HDD: 500gb Western Digital or Any other Recommendations
DVD Drive: Sony/LG/others or Any other Recommendations
Cabinet: Any Recommendations
PSU: Any Recommendations
UPS: Any Recommendations
Mouse: Logitech MX518 or Any other Recommendations
Keyboard: multimedia from Logitech or Any other Recommendations
Processor Cooling: Noctua NH-U12P SE2 120mm SSO CPU Cooler Extreme
I will be overclocking the Processor to 3/3.2 ghz.
pls mention the price of individual products.
where can i get a better deal on this products.
Im open to online purchase thru lynx-india or others.
Thanator is offline
Old 27-01-2010, 07:44 PM   #2 (permalink)
BE FREE
Default Re: Assembling a new PC for 80k, Need hardware suggestions!
^ you can your self check prices on lynx site, for the specs mentioned 80k would not suffice,
however wait, let the masters like krow, asig , desiibond and others suggest the best for you.
"To know that we know what we know, and to know that we do not know what we do not know, that is true knowledge." ~ Copernicus
azaad_shri75 is offline
Old 28-01-2010, 12:29 AM   #3 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
Processor: Intel Core i7 920 D0 - 14.8k
Motherboard: Gigabyte EX58-UD5 17.5k
RAM: G-Skill 2GB DDRIII 1333MHz - 2.6k
GPU: ATI 1GB GDDR5 HD5850(DX11) - 18k
HDD: Western Digital Green 1TB - 4.1k
Cabinet: CoolerMaster 590 - 3.8k
SMPS: Corsair TX 850W - 9.2k
Optical Drive: L.G. GH22NS30 SATA - 1.1k
Monitor: Benq 24" G2412HD - 11.6k
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 29-01-2010, 11:26 PM   #4 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
EDITED
Motherboard: Gigabyte EX58-UD3 14k
RAM: Corsair TR3X2G-1333 XMS3 C9 6GB Kit @ 7.8k
GPU: PowerColour HD5850 1GB GDDR5 @ 16.4k
HDD: Seagate 1TB 7200.12 @ 4k
Cabinet: CoolerMaster 690 - 4.4k
SMPS: Corsair TX 650W - 7k
Mouse: Logitech MX518 @ 1.5k
Keyboard: Razer Arctrosa @ 2.5k
TOTAL = 85.5k
The BOLD is the changes, go for the above config...
Well, I tried the best for the budget and requirements, but overshoots ur budget, if u save up 2.5k, u can get the CPU cooler of ur choice too taking the grand total to 88k, but if u really wanna go such high end, u can wait for Core i9 processors which will just replace the i7 i920 in this config...
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 01-02-2010, 01:41 PM   #5 (permalink)
Cool Buddy's Avatar
I think an Antec 550W SMPS should be sufficient for a single graphics card setup, Antec BP550 Plus 550W Modular is available for around Rs. 5k. in any case, 650W would be more than enough, you do no need to go for something like 850W. you can do with a cabinet of around 3000 to reduce the budget. Just check the graphics card price once, I'm not sure of it retailing around 17k.
finally, for such an expensive set up, it wouldn't be wise to buy a TN panel monitor, you would better go for an 8 bit IPS panel. Look for Dell's monitors, they are good in the IPS category.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 04-02-2010, 11:48 AM   #6 (permalink)
The Sorcerer's Avatar
Then its a waste to get a noctua u12pse2. Even a cogage/scythe mugen 2 that retails for around/under 3k odd is an overkill but you save money and still can get more than 3.2 ghz overclocks. If one is going to spend almost 8k for a 1333mhz cl9 kit they need to be shot in the head. Any reason why not to go for i5 750? It does 3.2ghz on stock VCORE easily, let alone anything more than that. Not all i7 920 D0 stepping overclock easily.
If you are planning to go for an i5+ 1600mhz kit, be advised. Most of the rams available in the market are without xmp profiles (google it out if you don't know what it is). Even if you do use rams with XMP profiles with 1600mhz, the problem is by default it reduces the multiplier and increases the base clock just to run on stock speed as far as gigabyte and DFI boards are concerned. FYI, 1333mhz cl9 ddr rams= 800mhz cl5 rams. There's simply no difference. For the money being saved here and there, better off taking an nzxt case IMHO.
IMO I think think you will need anything more than vx550. In any case, doing cable management with tx series is notorious and hardwork.
Hardware BBQ
The Sorcerer is offline
Old 04-02-2010, 08:55 PM   #7 (permalink)
BE FREE
where is the OP
Lock-In -hardware and software praka123 Random News 2 14-02-2008 01:15 PM
assembling the computer shivi4 QnA (read only) 1 11-07-2005 01:55 PM
Just what is DirectX? rajat22 Tutorials 1 11-06-2005 12:30 PM
Need ur Suggestions 4 Hardware khandu QnA (read only) 11 03-05-2005 06:48 PM
- by kool
