Originally Posted by krishnandu.sarkar
Do you use internet?? If yes I would like to recommend an online scan(If you are on unlimited plan).
yes i do have unlimited plan i wil try a online scan.
---------- Post added at 08:03 PM ---------- Previous post was at 08:01 PM ----------
Originally Posted by techie_85
What PSU do you have, since you have upgraded other components and not upgraded the power supply, there may not be enough power to run the Dvd player.
If that was the problem, then try removing any extra HDD or VGA cards and try to copy from the disk again.
yes i'm using the same psu(400w). but i only have 2 hdd,1case fan...will these consume more power
