Re: CPU cooler @2k
Coolermaster Hyper 212 ~2.3K. It is a bolt-down model, so you will need to remove the motherboard from the chassis. Do use the back place provided, else you board can bow. Also you will get some CM Fusion TIM, use with extreme prejudice.
