Old 08-01-2010, 05:57 PM   #1 (permalink)
Default Question about PSU
Hey guys
My system configuration is as follows
core 2 duo E4500 @ 2.20 GHz
Asus P5GC-MX motherboard
Zotac GeForce 9400GT graphics card 1GB GDDR2
1 GB DDR2 Ram
160 GB HDD
I just wanted to ask that if I upgrade my system to 2 GB Ram and add another 160 GB HDD will my PSU with 450W rating will be able to handle these components?
Thanks in advance.
ARJOT SINGH is offline
Old 08-01-2010, 07:50 PM   #2 (permalink)
Crowman
Krow's Avatar
Default Re: Question about PSU
Which company PSU is it?
If the system is running fine now, there is a very low probability of an HDD causing it to go kaput. I would worry when there are more than 2 HDD's though.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 10-02-2010, 02:54 AM   #3 (permalink)
No problem with that..I used to have 2 HDD - 160GB and 250 GB, 4850 GPU and 2 GB Ram and I never have a problem..Although get a real power PSU from known brands..
guile is offline
Old 10-02-2010, 06:45 AM   #4 (permalink)
Exclamation Re: Question about PSU
Well I don't think so adding a HDD or 2 will cause any problem with this configration....have your overclocked your CPU???
NJempire is offline
Old 10-02-2010, 09:48 AM   #5 (permalink)
geek........
Gauravs90's Avatar
How much power an HDD consume?
Gauravs90 is offline
Old 18-02-2010, 03:02 PM   #6 (permalink)
Welbeck fan :D
XTerminator's Avatar
this should solve your problem: http://www.msicomputer.com/index.php?func=power
the output wattage in your system should be always less generally,as thats the maximum possible value calculated (in the site above).
the modern drives use 15-25 watts at max.
XTerminator is offline
Old 18-03-2010, 06:11 PM   #7 (permalink)
Reviewerus Prolificus
Should not be a problem, though you should post the brand and model no. of your PSU.
CPU: Intel Core 2 Quad Q9650 (Ultima 90i cooled)
Mobo: ASUS P5K Deluxe
RAM: OCZ XTC PC8500 4x1 GB - 1066 MHz @ 5-5-5-15
Graphics: ZOTAC GeForce GTX 285 AMP! @ 700/2600 MHz
Storage: 1 TB WD Black + 500 GB WD 5000AAKS
OS: Windows Vista Ultimate x64 (genuine)
SMPS: Corsair HX 850W
Speakers: 'Sangram' modded Altec MX 5021
Cabinet: Lian Li A71F
Display: ViewSonic VX 2025 WM
Lucifer is offline
Basic guide for the right power supply The Sorcerer Power supply / Cabinets / Mods 717 25-04-2012 03:09 AM
Multiplayer games over LAN ~User Name~ Gamerz 26 24-10-2008 11:37 PM
Best online prank to scare your friends to death? go4saket Chit-Chat 16 28-09-2007 11:03 PM
PSU Fan Mod spynic Overclocking 11 30-08-2007 05:44 PM
Anybody can answer these hard questions?<<@@@>> Urgent Pleas khin007 QnA (read only) 7 18-04-2005 12:42 AM
- by kool
