Re: Computer turns off directly
@ vishald
hi buddy
Try out what asigh says.Download real temp and check your temp. after stressing it by using prime95 and post the screenshot using imageshack.
If the temperatures remain high then we will suggest you a good heatsink.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
