Old 04-01-2010, 02:31 PM   #1 (permalink)
nishant_nms's Avatar
Default CM 690 confusion
I am interested in getting CM 690... but am confused whether to go for pure black or not... and what's the difference between them... Please quote the price too...
nishant_nms is offline
Old 04-01-2010, 03:54 PM   #2 (permalink)
Default Re: CM 690 confusion
Go for Black, it looks cool. CM 690 comes for around 4.2K
f123 is offline
Old 04-01-2010, 03:58 PM   #3 (permalink)
Pure black comes for 4.2 only!!!
Old 04-01-2010, 10:45 PM   #4 (permalink)
Ya dude and if u pay 4.6k u will get the side transparent case...' it looks cool and if u wanna show off ur hardwares then put some led fans inside it...' go 4 it buddy its a great case...'
Arnab boss is offline
Old 05-01-2010, 03:26 AM   #5 (permalink)
Super Moderator
asingh's Avatar
What is CM690 + pure black..and CM690+non pure black..?
asingh is online now
Old 05-01-2010, 06:04 AM   #6 (permalink)
Revolution's Avatar
Is it CM690 II,the new one ?
Revolution is offline
Old 05-01-2010, 12:56 PM   #7 (permalink)
http://in.coolermaster.com/products/...e=2254&id=6718
http://in.coolermaster.com/products/...e=2254&id=4149
these are the links for both the cabinets...
Old 06-01-2010, 02:55 PM   #8 (permalink)
still waiting for suggestions....
Old 07-01-2010, 09:19 PM   #9 (permalink)
Dude just go 4 the transparent case and get some led 120mm fans...' it looks awesome and take a blue led fan....'
I hav it and tell u it looks great and deadly...
Old 07-01-2010, 09:37 PM   #10 (permalink)
Crowman
Krow's Avatar
A bit offtopic: LED fans are merely bling and not much of performance, unless you consider the Xigmatek Orange LED 120mm ones. If you are going to buy a case fan then go for Scythe Slipstream 120mm 1900RPM version. It should cost 475 bucks plus shipping if you buy online.
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 07-01-2010, 10:01 PM   #11 (permalink)
^^Not indeed there are good led fans out there
Specifically cm 120mm led fans that are 90cfm (tho in acutal they are 70cfm) for 450 rs
Xigmatek has recently launched f1251 120mm led fans with transparent frame and impellers rated at 63cfm/29dbA/1500rpm.
These two led fans make sense in decent cfm, noise levels and bling factor.
@OP get the basic cm690 for 4k. dont spend more on the black infact if u really want interiors black get a can of paint for 80 and do it yourself or get it powdercoated locally wud cost you less.
heavyarms is offline
Old 07-01-2010, 10:03 PM   #12 (permalink)
Crowman
Krow's Avatar
Those CM fans are pretty okay. I have used them and are surely not meant for CPU cooling. Only for case cooling. Meanwhile the Xigmatek ones are good heatsink coolers too.
Krow is offline
Old 07-01-2010, 10:04 PM   #13 (permalink)
what's the price of the transparent one
Old 07-01-2010, 10:20 PM   #14 (permalink)
The Sexy Beast
4.4k got it yest
ratedrsuperstar is offline
Old 07-01-2010, 10:24 PM   #15 (permalink)
Originally Posted by ratedrsuperstar View Post
4.4k got it yest
simple one??
Old 07-01-2010, 11:05 PM   #16 (permalink)
Super Moderator
asingh's Avatar
Yea, they look really nice. But with the transparent CM690, the light bleeds through. If it is in your sleeping room -- errr..a bit of a pain.
Old 08-01-2010, 08:47 AM   #17 (permalink)
Crowman
Krow's Avatar
and a loss of sleep if you leave your rig on at nights.
Krow is offline
Old 08-01-2010, 09:19 PM   #18 (permalink)
^^^ GUYS I hav a separate computer room so no probs 4 me...'
@krow I hav 7 fans 4 led and 3 normal and it keeps my rig cool and noise is tolerable....'
@op don't get confused if u wanna some fancy case then look @haf 922 @6k....its hardy with side transparent and good cooling features...'
Old 09-01-2010, 02:40 AM   #19 (permalink)
Super Moderator
asingh's Avatar
Well I have 7 too. 5 LED, and 2 normal.
Old 09-01-2010, 09:31 AM   #20 (permalink)
Crowman
Krow's Avatar
Also, have a look at the Lancool Dragonlord PC-K62 @ 7k and PC-K56 @ ~5k, if you can find it. Look for deals online.
Krow is offline
price of coolermaster cm 690 cabinet himadri_sm QnA (read only) 1 14-05-2008 06:20 PM
confusion confusion!! genx069 Mobiles and Tablets 2 28-10-2007 04:23 AM
SATA RAID Confusion and Optical Drive Confusion bbalegere QnA (read only) 2 20-05-2007 07:00 PM
AMD 690 series chipsets to launch in February s18000rpm Technology News 1 04-02-2007 09:55 AM
uplinking 2 hubs together???? a little confusion....... taken Hardware Q&A 2 29-06-2006 06:53 PM
- by kool
