Old 28-12-2009, 12:46 PM   #1 (permalink)
Question A Low- End Gaming PC
Hi guys,
I was thinking of upgrading my CPU. Only CPU. My budget is around Rs. 20000/-, so its a low end gaming PC.
I want either Intel or AMD Dual or Quad Core (6 or more GHz) Processor, a motherboard, a 4GB DDR2 RAM, 350-500 GB hard disk, DVD Writer, a cabinet, and a graphics card.
I have no idea about graphics card, so was thinking that you all might tell me something. I dont want to play games in highest resolutions. As long as I can play games like Assassain's Creed, GTA 4, latest NFS etc even in low resolution it will do. As long as there is no glitch while I play there is no problem.
Will it fit in my budget? Please suggest.
I already have Viewsonic 17" widescreen TFT (1440x900) so I don't need monitor.
Also I'm selling my old CPU which has Intel Pentium Dual Core Processor (2x 1.6 GHz), ASUS P5GC-MX Motherboard, ASUS DVD Writer and Gigabyte 2.5GB DDR2 RAM. Its 2 years old now.
Can I use something from my old PC??
How much can I expect as resale price for old PC?
Nin13 is offline
Old 29-12-2009, 11:07 AM   #2 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Default Re: A Low- End Gaming PC
u can get 6-8k for ur system i guess...i dunno really
CONFIG:-
Athlon II X3 435 2.9GHz @ 4k
MSI 785GM E51 @ 4.6k(AM3 DDR3)
2GB DDR3 1333MHz Transcend @ 2.5k
Seagate 500GB HDD @ 2.4k
Keep ur DVD Writer
Zebby Krish @ 1k
Gigabyte 460W @ 2.2k
This makes ~16k
Now u get say 6k from old rig...so u hav in hand 10k...
U hav following options for G.Card:-
Sapphire HD4770 Artic Cooling @ 7.4k
Sapphire HD5750 @ 8.8k
Sapphire HD5770 @ 10.8k
Make ur pick...
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 29-12-2009, 12:12 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
R u saying 6GHz or More
Zangetsu is offline
Old 29-12-2009, 12:32 PM   #4 (permalink)
Simply a DIGITian
krishnandu.sarkar's Avatar
I wud like to replace the proccy suggested by comp@ddict with AMD Athlon II X4 920. The mobo he suggested is gr8, it has ATI chipset inbuilt and will handle all the recent titles in low/med settings. And wud like to change the HDD from Seagate to WD.
After the change in proccy u'll be left with 8k approx. So u can get a graphics card also......At that budget a 9600GT or as suggested by comp@ddict
  • Read The Forum RULES First.
  • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
  • Before Starting A New Thread Read The STICKY THREADS First
  • Before Participating In Bazaar Section Read The BAZAAR RULES
krishnandu.sarkar is online now
Old 29-12-2009, 03:01 PM   #5 (permalink)
laborare est orare
Cilus's Avatar
Krishnendu, u won't be able to plug Phenom II 920 into an AM3 borad because it is a AM2+ socket processor. You can put AM3 processors in AM2/AM2+ board but the reverse is not true because AM3 boards have 938 pin socket where as AM2 processors have 940 pins. the AM3 version of 920 is 925@7.4k.
But if you wanna suggest a Quad core Processor, Athlon II 620 X4 is a far better choice at the budget mentioned.
Cilus is offline
Old 02-01-2010, 02:19 PM   #6 (permalink)
I mean around 3.0GHz, bcoz its dual core it becomes (3.0x2= 6.0GHz)
---------- Post added at 02:16 PM ---------- Previous post was at 02:15 PM ----------
CONFIG:-
Keep ur DVD Writer
Zebby Krish @ 1k
This makes ~16k
Make ur pick...
Hey!! Thanks for the advice!!
---------- Post added at 02:19 PM ---------- Previous post was at 02:16 PM ----------
Also, Can anyone tell me what are prices of EXTERNAL HARD DISC say 500GB??
Nin13 is offline
Old 02-01-2010, 07:27 PM   #7 (permalink)
Crowman
Krow's Avatar
No, It does not become 6GHz. If you think it does, then please post a link which says so.
External as in? Do you want a portable 2.5" which uses the USB port as a power source or is it the large dumpbag which needs a plug point?
As for the portable one: 500GB Seagate/WD/Verbatim all are around 3.8k-4.2k
As for the dumpbag: 1TB WD My Book Essential is for 5.1k
Thinkdigit Forum Workspace Showoff Contest
Abusive, offtopic post? Use the report post button.
Read before messaging any moderator for any query: FAQ + answers for new members
Ignorance of FORUM RULES is no defence.
Krow is offline
Old 02-01-2010, 07:33 PM   #8 (permalink)
Simply a DIGITian
@Cilus Thanx buddy......I was trying to say what you said. And thanx for the information. I really didn't noticed.
Old 02-01-2010, 07:38 PM   #9 (permalink)
Crowman
Krow's Avatar
A small correction: AM3 socket has 939 pins and not 938.
Krow is offline
Old 04-01-2010, 07:06 PM   #10 (permalink)
Thumbs up Re: A Low- End Gaming PC
Ok.... sorry my PC knowledge is not very good.
Yes, I want the one with USB port as power source!! Thanks!!
Nin13 is offline
Old 04-01-2010, 11:26 PM   #11 (permalink)
laborare est orare
Cilus's Avatar
now with the latest price updates from AMD, u can go for a better config
Here goes ur Suggestion
AMD Athlon II 620 X4 @ 4.6k
Kingston 2 GB DDR3 1333 MHz Ram @ 2.4k
Gigabyte GA-MA785GMT-UD2H @ 5.5k
500 GB SATA II Seagate @ 2.3k
Zebronics Krish Cabinet @ 1.2k
Gigabyte 80 Plus Active PFC 460W PSU @ 2.2k
XFX HD4850 512MB GDDR3 @ 6.3k
Total 24k
Cilus is offline
Sony PlayStation 3 (60GB) kinshuk99 Gamerz 6 16-06-2007 12:02 PM
Whats the difference between a PC & a MAC iMav QnA (read only) 163 16-05-2007 02:37 PM
Piracy pushing Epic, id away from PC gaming unni Random News 2 12-03-2007 11:23 PM
fast, low ping, low latency, high data rate ports for multiplayer gaming MambaXL Gamerz 1 30-01-2007 03:31 PM
All configuration (new and upgrades) related queries here abhijit_reddevil PC Components / Configurations 372 17-06-2006 05:34 PM
- by kool
