28-12-2009, 10:30 AM
My 2 Day Old Laptop everything messed up Please help..
I got an laptop from my college, Lenovo e43, it came with 250 GB HDD, 3 GB Ram, and windows 7 profestional preinstalled.
It has one key Rescue system button, it restores system to factory default.
Everything was fine,
The system came with 2 partitions one C: which had 187 G, in which windows 7 was installed. other D: which had 40gb it was
empty had 600mbs of drivers folder.
the system had 2 more partions which are hidden, for Os recovery purpose.
I thaught of making 2 more partions by removing free space from C drive. I shrinked 100 GB using built in diskmanagement
tool of windows 7. it shrunk and created 100 GB of unallocated space, while creating new simple partion it was giving an
error message as "cannot create, maximum partitions are already created"..
So i googled a lot and found the solution. i downloaded paragon partition magic and installed it, it did my job easily.
without any problem i created 2 new partions of 50 GB each, drive E: and F:, it created successfully and now i could see 4
partions in my computer, C, D, E and F.. and copyed many music files and movies to that drives, i worked few hours and i
shut down my lap and wen to bed,
when i got up in the morning and i switched it on, its not booting, it shows full blank screen which shows only "_" mark in
the top left corner of the screen. when i switch on it shows lenovo logo and and to enter bios f2 and to select boot menu
f12 screen thats it and then it completes goes black not booting.. i tryed many times but no success.
I can go to bios, i went there loaded default values then also no where it booted.
Then i thaught of one key Rescue system button, and pressed it it started but it did not launch the Rescue system software
instead it launched CMD window
with an line
x:/windows/system32/
and thats it if i close that window it exits and restarts and again old story of black screen.
I really fed off i need to take my laptop to college tommorow,
So please guys anyone provide an solution to recover my OS to factory default, i dont mind for files dleted.
Just show me the way to restore my sytem to factory defaults using one key Rescue system button.
Gigabyte GA-EP31-DS3L, C2D E8400, 2GBx2 DDR2800 RAM, WD 640 GB HDD (16MB Buffer)
CM Extreme Power 500WATS SMPS, Expertvision HD4850
