Old 26-12-2009, 11:51 PM   #1 (permalink)
nishant_nms's Avatar
Default Suggest a cabinet within 2K
Hi,
Please suggest me a cabinet. My budget is 2K....
thanks in advance
nishant_nms is offline
Old 26-12-2009, 11:58 PM   #2 (permalink)
live life king like...
hot zubs's Avatar
Default Re: Suggest a cabinet within 2K
Zebronics bijli @ 1.6k with PSU...
Core i5 2400, Intel DH67BL-B3, 2GB Corsair DDR3, Geforce 8600GT, Seagate 1TB, LG 20x , BenQ E2220 HD, Creative M4500 , CM extreme 600W, CM 690, APC BackUPS -ES650VA
hot zubs is offline
Old 27-12-2009, 10:47 AM   #3 (permalink)
Suggest me a cabinet without PSU.. as I already have Corsair VX 450....
I am upgrading my Graphics to HD 5770... So I need a good ventilated cabinet...
Old 27-12-2009, 11:07 AM   #4 (permalink)
I am the night! I am....
vickybat's Avatar
Smile Re: Suggest a cabinet within 2K
hi nishant
For the cabby go for the cm elite 335 for around 0.3k more. Its lot better than zebby bizli.
core i5 750, biostar h55 A+ (X16+X4), 4gb 1333 ddr3, corsair vx450, cm elite 335,Asus EAH 5750 FORMULA , samsung 2033 sw plus, wd green 1tb , wd 1tb my book , hp dvd writer,Apc 650 va, logitech z313
vickybat is offline
Old 27-12-2009, 11:34 AM   #5 (permalink)
waiting for few more suggestions...
Old 27-12-2009, 05:18 PM   #6 (permalink)
Off Hook!
v.Na5h's Avatar
try Gigabyte GZ-x3 at 1.4k
good case iam considering it after dropping the ideo of getting Bijli
---------- Post added at 05:18 PM ---------- Previous post was at 05:16 PM ----------
hey is the led visible when we add a front 120mm led fan to the GZ-x3
Core i3 530 @ 2.93Ghz | Kingston 4GB (2GBx2) DDR3 1333MHz | Gigabyte GA-H55M-S2H | Acer S231HL 23" LED Monitor | Nvidia GTS 450 | Seagate Barracuda 1TB | FSP Saga II 350w | CM Elite 310 | | Philips HTS 5.1 SP100
| Zotac GTS 450 |X360 Gamepad |
Dell XCD35 powered by CM9, Soundmagic PL11 earphones, Samsung class 6 16GB
TV Shows / Movies .....I have watched....
v.Na5h is offline
Old 29-12-2009, 11:22 AM   #7 (permalink)
no other suggestions!!!
Old 29-12-2009, 12:15 PM   #8 (permalink)
Fullbring
Zangetsu's Avatar
+1 for CM cabinets totally rock solid performance
Zangetsu is offline
Old 31-12-2009, 05:00 AM   #9 (permalink)
I also agree with CM Elite 335.
ico is offline
Old 31-12-2009, 09:37 AM   #10 (permalink)
The Sorcerer's Avatar
Stick to elite 33x series. As it is bijli's overall built quality slided down over the months so doesn't make sense spending 1.5k for that.
Hardware BBQ
The Sorcerer is online now
Old 31-12-2009, 11:35 AM   #11 (permalink)
What is the cost of CM 690
Old 31-12-2009, 12:02 PM   #12 (permalink)
harryneopotter's Avatar
^^ CM 690-4.5k
Wats the Favourite Mathematical Function of DIGIT FORUM ????
Its "A SINE WAVE" constant
Y ??
They Both keep going "UP AND DOWN, UP AND DOWN............" !!!!!!!!
harryneopotter is offline
Old 31-12-2009, 01:25 PM   #13 (permalink)
Please suggest a good online store or a shop in Pune...
Old 31-12-2009, 02:24 PM   #14 (permalink)
Cool G5's Avatar
Order from PrimeABGB online.
Cool G5 is offline
Old 01-01-2010, 12:12 PM   #15 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
not really
depends on which cooler version u r getting, as the old one blows hot air out of the case
and upgrade the rest of ur computer before gfx card as it's gonna be crying with a AthlonXP+
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 01-01-2010, 12:17 PM   #16 (permalink)
Originally Posted by comp@ddict View Post
not really
don't worry I am getting a i5 with new mobo and 4GB RAM too
Old 03-01-2010, 11:03 AM   #17 (permalink)
I am having a change in plan... I am getting interested in CM 690... but am confused whether to go for all black or not... and what's the difference between them... Please quote the price too...
Or in case I go for CM elite 33x series... will they easily accommodated 5770 or other bigger cards??
And is there any difference between elite 334 & 335... feature wise or cost wise...
Old 03-01-2010, 01:26 PM   #18 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Get this config:-
i5 i750 2.66Ghz @ 9.8k
MSI P55 UD2 @ 6.8k
4GB DDR3 1333MHz Transcend @ 5k
CM Elite 330(side transparent) @ 2k
Sapphire HD5770 1GB GDDR5 @ 10.9k
And what's the max resolution of ur monitor? HD5770 can max games at 1600x900/1680x1050 and maybe u hav to tuen AA down(to 0 or 2x) for 1920x1080...
About me:
Old 03-01-2010, 04:55 PM   #19 (permalink)
Can CM elite 33x series... will they easily accommodated 5770 or other bigger cards??
Old 04-01-2010, 01:25 PM   #20 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
they can accomodate uptil HD4850, HD5770..
HD4870, HD4890, HD5850 are a li'l difficult to place, but hey it's possible!(luk at me!)
About me:
[Modding] Cooler Master Storm Scout Cabinet – Ramp Walk Rollercoaster Overclocking 6 31-03-2010 09:45 PM
Good Cabinet around 2k or less Tech_Wiz Hardware Q&A 11 14-10-2009 10:35 PM
Please suggest a Lin friendly PC config + 3 Distros (multi boot) for School Students din Open Source 29 05-10-2007 05:27 PM
Plz suggest Config --- AMD 64.... Max_Power CPU / Motherboards 3 03-07-2005 11:34 AM
pls suggest ne gud cabinet supersaiyan QnA (read only) 15 13-05-2005 11:55 AM
- by kool
