Old 07-07-2005, 06:40 AM   #1 (permalink)
Location: In the Internet world does it matter wherever I stay?
Default My system reboots with/with out warning.....?
I use a PC with mercury mother board PIII 733 MHz 256 SDRAM 20GB HDD with windows XP. All the while ( almost close to 4 years) it worked well. Suddenly it starts giving a notice on a blue screen that windows encountered a problem. I did formatting with dual booting OS windows98 on C drive and XP on E drive. Windows98 is working well and i ve no problem. But to my demise XP is rebooting again in few minutes of booting but without any notice this time. How do I solve this problem? I ve refered to few local experts but no result.
I am a novice in this field. i use PC for internet browsing for e- books, mails and chat etc.
plz help me. :roll:
Thanks in advance
Sri
srguduru is offline
Old 07-07-2005, 06:45 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
can u pls tell what does the blue notice say ?
when does it happen? within few minutes of start-up ? anytime? or only when u r on the internet ? did u install any new programs ?
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 07-07-2005, 10:28 PM   #3 (permalink)
i think u got urself infected with virus on XP. do a complete scan and see.
plus clean ur cpu cabinet with brush and also ur RAM contact points this will surely help
Have a Nice Day
Mohammed Muchhala, © 2006, All Rights Reserved
http://www.muchhalasworld.com
babumuchhala is offline
Old 08-07-2005, 08:04 PM   #4 (permalink)
I too have the similar problem, but uninstalling some softwares related to the internet and doing a system checkup and registry cleanup using 'System mechanic' and then reinstalling those softwares i uninstalled, solved my problem. And howover if it is a legal copy of Windows XP, then updating it with the service pack 2 may solve the problem most probably.
Yesterday - Dead
Today - Dying
Tomorrow - Never dies
The day after tomorrow - Where will you be !
Sreekanth V is offline
Old 09-07-2005, 11:12 AM   #5 (permalink)
anomit's Avatar
Try pressing F8 just after ur BIOS screen disappears and you would be presented with some options. There may be an option like "Disable automatic restart on system failure". Then see what the error message says and if possible post a screenshot of it.
Don\'t SYN me, I'll SYN you.
anomit is offline
Old 29-04-2008, 12:01 AM   #6 (permalink)
Default Re: My system reboots with/with out warning.....?
ok ! solved da problem.
srguduru is offline
