since the mobo is old its not mentioned in intel site
They r saying that it supports pentium d family, pentium 4 family n celeron
only and it was last updated in 2006.
My doubt is that do the dual core family E52,E53 n E54support d101ggc mobo?
coz they are the same pentium family having fsb of 800Mhz
Athlon II X4 630 @ 3.5 Ghz|CM Hyper TX3|Biostar TA790GX A3+|4GB DDR3 1333 ADATA|750 GB HDD Seagate|Sony DVD RW|Sapphire HD 6850 1GB|Samsung 2033SW|Creative Inspire T6100|Realwatts Pro 500W|APC 650VA
The C2D line of CPUs will dock to the LGA775 on your D101GGC. But they will not work. The D101GGC chipset/BIOS is not compatible with the C2D(E)/C2Q(Q) series.
