Old 23-12-2009, 12:46 PM   #1 (permalink)
Exclamation External Hard disk not detected
Hello frnds by mistake i had plugged 19v laptop adapter instead of 12v adapter to my seagate freeagent 1TB..
Now my hard disk is not switching on.
Will it can be repaired and data be recovered
once i opened it i found a capacitor sort of thing little burnt up..so i removed the 3.5" harddisk and connected it parrallely to my normal sata hard disk to check if hard disk is not faulty
PC config in which i connected was
pentium 4 old one
256mb ram
but once i connected the system does not boot up..
may be becoz of the over limit of the HD size supported by my mobo
so does it mean my 1TB hard disk is safe and only power circuit is faulty
pls help
surenther.ss is offline
Old 18-01-2010, 08:42 AM   #2 (permalink)
harishgayatri's Avatar
Default Re: External Hard disk not detected
System does not boot up?
What do you mean?
Does it show the POST screen?
harishgayatri is offline
Brand new hard disk not being detected. jawash QnA (read only) 2 04-06-2008 04:53 AM
Hard Disk makes noise & not detected g_goyal2000 Hardware Q&A 8 25-05-2008 07:44 PM
booting from external hard disk desijays Hardware Q&A 3 25-11-2006 08:58 AM
what exactly is a RAID hard disk ? go_gamez QnA (read only) 10 13-09-2006 08:26 PM
External Hard Disk varun_ag QnA (read only) 12 28-04-2005 10:56 PM
- by kool
