Old 22-12-2009, 09:36 PM   #1 (permalink)
The Sexy Beast
Question Monitor 24inch vs CPU cooler+monitor 22inch
for a budget of 12k what would be ideal? afaik the benq 24inch comes for 11.5k
or should i buy a 22inch (recommend a model) + Arctic Cooling Freezer 7 Pro Rev2
i need a 1080p monitor.is running at 1080p on 22inches the same as running 1024x768 on a 15inch??
current config
intel e7200 OCed to 3.1Ghz
abit ip35-e mobo
Gigabyte 9600GSO 384mb
ratedrsuperstar is offline
Old 22-12-2009, 09:46 PM   #2 (permalink)
Welbeck fan :D
XTerminator's Avatar
Default Re: Monitor 24inch vs CPU cooler+monitor 22inch
http://reviews.cnet.com/lcd-monitors...-32906371.html
i fancy samsung t240hd.though 2400w ftw as well.
also check these mfers:
http://reviews.cnet.com/lcd-monitors....html?tag=also
and
for its price
XTerminator is offline
Old 22-12-2009, 10:06 PM   #3 (permalink)
Super Moderator
asingh's Avatar
current config
abit ip35-e mobo
Will you game....?..GPU...?
asingh is online now
Old 23-12-2009, 06:01 PM   #4 (permalink)
The Sexy Beast
9600gso. i only play pro evolution soccer.
Due Kernel I/O error, system refuses to boot randomly gary4gar Open Source 33 04-05-2008 10:22 AM
Please List Basic C2D / Dual Core Overclocking Tips Choto Cheeta Overclocking 101 18-12-2007 09:31 PM
Nokia Processors - Hope its useful! solomon_paulraj Mobiles and Tablets 4 31-10-2007 02:57 PM
- by kool
