I want to buy a LCD TV and following are my requirements
1. Size - Minimum 46" and 1080p resolution
2. Will be used for normal cable TV (incablenet) and if you guys suggest that it wont look good, i may switch to Tata Sky / Big TV/ Airtel DTH etc
3. Maximum SD content and will watch HD stuff occassionally but not on a daily basis.
4. Will sometimes connect with laptop (through HDMI / VGA) to use as monitor but that will be ocassional and only for fun.
5. Will be using with my PS2 console (no intension of buying PS3 etc anyime soon)
6. Will be used with my Eaget M880 media player through HDMI to watch HD and SD stuff.
7.USB input to TV with media playing capability is not a priority as dedicated media player will be used.
8. Should be easily wall mountable and should look good.
9. Good Sound would be preferred as am not buying a 5.1 system anytime soon. But if TV comes out to be cheaper than i expect i may squeeze the 5.1 also but that is last to last priority.
10. A VFM model of brands either Sony / Samsung / LG (if they are good).
11. Budget - Nothing fixed but i think i can stretch to 1 Lakh (inclusive everything) if it deserves the price but not over that. But cheaper the better.
12. Will be buying in a month or so.
I hope i am not asking too much, just clearing my exact requirements. I have not had look at any models as such and not been to any shop. Based on your suggestion i will go to croma, vijay sales, Hypercity etc in Mumbai (Borivali to Andheri area) and have a look. If you can suggest some other shops that will also be good.
